[postgis-devel] [PostGIS] #272: ST_LineCrossingDirection should be negatively symmetric
PostGIS trac at osgeo.org
Fri Oct 16 23:42:59 PDT 2009
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  postgis 1.4.1
Component:  postgis  |     Version:  1.4.X
 Keywords:           |
 I propose that to minimize on confusion
 It should hold true that:
  ST_LineCrossingDirection(a,b) = - ST_LineCrossingDirection(b,a)
 --- below is a relevant excerpt from the previous crashing ticket  -
 Regina
 But I think there is still a problem.
 In our documentation -- We still have this example that doesn't behave
 right
 SELECT ST_LineCrossingDirection(foo.line1, foo.line2) As l1_cross_l2 ,
     ST_LineCrossingDirection(foo.line2, foo.line1) As l2_cross_l1
 FROM (SELECT
     ST_GeomFromText('LINESTRING(25 169,89 114,40 70,86 43)') As line1,
 ST_GeomFromText('LINESTRING(2.99 90.16,71 74,20 140,171 154)') As line2 )
 As foo;
 (gives me -2, 0)
 http://www.postgis.org/documentation/manual-
 svn/ST_LineCrossingDirection.html
 Mark's Response
 Yeah; I see exactly the same answers. Unfortunately though, I can't make
 much sense of the integer constants in the manual to work out what the
 function *should* actually be doing. Can anyone explain this in more
 detail? For example, do the LEFT/RIGHT parts refer to spatial position or
 the order of the input parameters?
 ATB,
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/272>
