[postgis-devel] Multi-Lingual Docs
Kevin Neufeld kneufeld at refractions.net
Fri Oct 23 17:52:45 PDT 2009
I think it's a great idea.  I was noticing when we started the
documentation face lift how docbook does indeed make multilingual
support easy.
The only thing is, whenever someone submits a patch to the
documentation, they'll have to remember to record the patch in a
documentation bug report so that someone qualified can tackle the
translation to other languages.  I foresee one documentation bug report
category for every language we plan to support.
Cheers,
Kevin
Paul Ramsey wrote:
> Hi All,
> I'm at the FOSS4G code sprint today, and have been discussing
> multi-lingual documentation with Til Adams and Daniel Kastl. Given
> that we've had 3rd party translations to fr and pt in the past, it
> would be great to pull the i18n community into the main documentation
> process, by making the docs multi-lingual.
> This project seems to provide a template for doing multi-lingual
> docbook in unified way, with a minimal amount of duplication (in
> particular, we want to avoid duplicating things like the diagram
> generation and the SQL code examples and so on across translations).
> http://docbooksml.sourceforge.net/
> The translations then end up looking like this:
>     <title>
>       <phrase lang="en">What is DocBook.sml?</phrase>
>       <phrase lang="de">Was ist DocBook.sml?</phrase>
>     </title>
> The translation blocks can be as granular (as above) or blocked (doing
> whole sections in translation or whole chapters) as you want. So we'd
> probably have different granularity in different sections. Reference
> manual very granular (because there's so much code example and
> parameter stuff that is language-independent) and tutorial sections
> less granular (because there's so many translatable words in blocks).
> Til is doing some experiments with docbooksml and will show us what a
> working multi-lingual set-up would look like when he gets it running
> (posting a postgis source tarball with the multilingual approach
> implemented that we can download and try). Then we can decide
> how/if/when to integrate it into our working doc system.
> Thoughts?
> Paul
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
