[postgis-devel] [PostGIS] #253: Gist causes wrong result from ~=
PostGIS trac at osgeo.org
Mon Oct 26 02:00:20 PDT 2009
  Reporter:  nicklas  |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.4.1
 Component:  postgis  |     Version:  1.3.X
Resolution:           |    Keywords:
Comment (by nicklas):
 I just noticed that ~= is defined in postgresql too. As I read it there is
 the same definition as postgis of today that the geometries should be "the
 same" to return true even if the example given, makes me quite confused if
 the order of vertexes matters or not.
 http://www.postgresql.org/docs/8.4/static/functions-geometry.html
 just a note toplans of changing ~= to just compare bboxes from the
 discussion above.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/253#comment:30>
