[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
PostGIS trac at osgeo.org
Mon Oct 26 14:38:20 PDT 2009
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 Olivier,
 Sorry for taking so long to get back to you.  Under a lot of time
 pressures with other projects this week so you probably won't here much
 from me for at least another week or 2.
 Regarding the attached.  It doesn't compile for me at all.  Gives errors
 like
 lwgeom_in_gml.c:2179: warning: type defaults to `int' in declaration of
 `name'
 lwgeom_in_gml.c:2179: error: syntax error before '<' token
 lwgeom_in_gml.c:2181: warning: type defaults to `int' in declaration of
 `name'
 lwgeom_in_gml.c:2181: error: syntax error before '<' token
 lwgeom_in_gml.c:2183: warning: type defaults to `int' in declaration of
 `name'
 lwgeom_in_gml.c:2183: error: syntax error before '<' token
 lwgeom_in_gml.c:2185: warning: type defaults to `int' in declaration of
 `name'
 lwgeom_in_gml.c:2185: error: syntax error before '<' token
 lwgeom_in_gml.c:2187: warning: type defaults to `int' in declaration of
 `name'
 lwgeom_in_gml.c:2187: error: syntax error before '<' token
 lwgeom_in_gml.c:2189: warning: type defaults to `int' in declaration of
 `name'
 lwgeom_in_gml.c:2189: error: syntax error before '<' token
 lwgeom_in_gml.c:2195: warning: type defaults to `int' in declaration of
 `geom'
 lwgeom_in_gml.c:2195: error: redefinition of 'geom'
 lwgeom_in_gml.c:2173: error: previous definition of 'geom' was here
 lwgeom_in_gml.c:247: error: previous definition of 'geom' was here
 lwgeom_in_gml.c:2195: error: syntax error before ')' token
 lwgeom_in_gml.c:2197: error: syntax error before ')' token
 lwgeom_in_gml.c:2223: warning: type defaults to `int' in declaration of
 `xa'
 lwgeom_in_gml.c:2223: error: redefinition of 'xa'
 lwgeom_in_gml.c:2149: error: previous definition of 'xa' was here
 lwgeom_in_gml.c:1401: error: previous definition of 'xa' was here
 lwgeom_in_gml.c:2223: warning: data definition has no type or storage
 class
 lwgeom_in_gml.c:2223: error: syntax error before '<' token
 and goes on and on.  The gml in BTW works fine on my OpenSUSE 10.3 (using
 the same libxml source) (haven't tried my more finicky 11).  Even going
 thru the gardent test seems to work fine.
 I think its an issue with compiling libxml2 under mingW.  I searched, and
 it seems stories are the same with the libxml crashing when compiled under
 mingw.  Possibly threading issues or something.  the compile of libxml2
 also gives a ton of warnings about exceeded length of the form
 .libs/lt-testModule.c:285: warning: string length `1611' is greater than
 the length `509' ISO C89 compilers are required to support
 So I fear this may be beyond my abilities to solve.  Perhaps Mark can take
 a stab at it when he has the time to see if there is a trick to getting
 this to behave correctly.
 My newer mingw 4.4 compiler refuses to even compile the libxml2.
 Thanks,
 Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:2>
