[postgis-devel] [PostGIS] #279: hausdorff regression test fails
PostGIS trac at osgeo.org
Fri Oct 30 05:47:38 PDT 2009
 Reporter:  mloskot    |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  postgis 1.5.0
Component:  postgis    |     Version:  trunk
 Keywords:  hausdorff  |
 Running regression tests against PostGIS from current trunk (r4706) gives
 failure for the ''hausdorff'' test
 hausdorff. failed (diff expected obtained:
 /tmp/pgis_reg_25454/test_44_diff)
 and it looks it crashes the server
 $ cat /tmp/pgis_reg_25454/test_44_diff
 *** hausdorff_expected  2009-07-30 10:28:11.000000000 +0100
 --- /tmp/pgis_reg_25454/test_44_out     2009-10-30 12:38:58.000000000
 +0000
 *** 3,6 ****
   hausdorff_ls_ls_2|2
   hausdorff_ls_mp|1
   hausdorff_ls_ls_3|14.142135623731
 ! hausdorffdensify_ls_ls|70
 --- 3,9 ----
   hausdorff_ls_ls_2|2
   hausdorff_ls_mp|1
 ! server closed the connection unexpectedly
 !       This probably means the server terminated abnormally
 !       before or while processing the request.
 ! connection to server was lost
 Environment:
  * Linux 64-bit
  * GCC 4.4.1
  * GEOS (version 3.2.0 from SVN trunk
 [http://trac.osgeo.org/geos/changeset/2710 2710])
Ticket URL: <http://trac.osgeo.org/postgis/ticket/279>
