[postgis-devel] [PostGIS] #280: in_gml regression test fails
trac at osgeo.org
Fri Oct 30 05:59:06 PDT 2009
Reporter: mloskot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Keywords: |
Running regression tests against PostGIS from current trunk (r4706) gives
failure for the ''in_gml'' test
in_gml. failed (diff expected obtained: /tmp/pgis_reg_27721/test_45_diff)
and it looks it crashes the server
$ tail -n 2 /tmp/pgis_reg_27721/test_45_diff
--- 1 ----
! psql: FATAL: the database system is in recovery mode
I did full rebuild of both, PostGIS and GEOS.
Full test log attached.
The problem may be related to bug reported in #273.
Environment:
* Linux 64-bit
* GCC 4.4.1
* GEOS (version 3.2.0 from SVN trunk
[http://trac.osgeo.org/geos/changeset/2710 2710])
Ticket URL: <http://trac.osgeo.org/postgis/ticket/280>
