[postgis-devel] Sphere or Spheroid
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 30 16:41:09 PDT 2009
Oh, BTW, we could just as easily have a utility function
geography_set_spheroid(bool) that you can call from SQL that will
manipulate the global variable. That's all that the SET command ends
up doing in the end anyways.
P.
On Fri, Oct 30, 2009 at 4:29 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Ah okay, maybe that was why we decided against it last time. You should put
> that in the notes. Anyrate even if we had GUC, I would still go with the
> multiple signatures as well since you may want different behavior for a
> specific query or when you are comparing numbers (you want both).
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Friday, October 30, 2009 7:25 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Sphere or Spheroid
> I did GUC research this morning and even did a GUC implementation! I don't
> think it makes this decision any less relevant, because frankly the default
> will rule 95% of the users. So choosing the "right"
> default is a good idea.
> Anyhow, on the GUC, a module-controlled GUC has an issue, in that the GUC
> can't exist until it's initialized by the module, and the initialization
> routine for the module is not executed until the first time a module
> function is called. So, running "SET geography.use_spheroid = true" will
> return an error if it's the first thing you do, but will work if you first
> do something like "SELECT ST_AsText('POINT(0 0)'::geography)" to force the
> module to load
> In all, a non-happy situation, so I have opted for function signatures for
> now, unless someone can tell me I should do otherwise.
> P.
> On Fri, Oct 30, 2009 at 4:10 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> I'm still dreaming of the GUC by the way.
>> http://trac.osgeo.org/postgis/ticket/267 to make this decision less
>> relevant.
>> What is bool (will that mean True if you want measured in sphere?).
>> Regardless of what default you decide, that boolean has to mean the
>> same thing I think. (but I guess that's not too important)
>> Thanks,
>> Regina
>> Paul Ramsey
>> Sent: Friday, October 30, 2009 4:41 PM
>> I should add that in general, the differences seem to be about 0.1% to
>> 0.2% for my Oregon test area.
>> P.
>> On Fri, Oct 30, 2009 at 1:39 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>>> I am just now hooking up some spheroid calculations into SQL and the
>>> choice is here: what is the default return for ST_Distance(geog,
>>> geog) ? I have an extra signature ST_Distance(geog, geog, bool) which
>>> allows you to choose, *but* something has to be the default. So, slow
>>> and accurate or fast and not-quite-right? For reference, here's some
>>> test
>>> numbers:
>>> spheroid | sphere | diff | diff_pct
>>> 14.1244075108035 | 14.1394160043876 | -0.0150084935841761 |
>>> -0.00106146488507862
>>> 14.6266188748041 | 14.5910056309084 | 0.0356132438956287 |
>>> 0.00244076692151968
>>> 20.7346086743544 | 20.7259709082645 | 0.00863776608995082 |
>>> 0.000416760504402065
>>> 21.9682444424626 | 21.9811452394388 | -0.0129007969762469 |
>>> -0.000586902858596291
>>> 23.7383733187578 | 23.7519404190066 | -0.0135671002487641 |
>>> -0.000571199658193295
>>> 24.71417232105 | 24.6751858115921 | 0.0389865094578177 |
>>> 0.00157998848541607
>>> 26.060846145618 | 25.9957171978245 | 0.0651289477934469 |
>>> 0.00250537222334829
>>> 29.1593418185795 | 29.0828389449609 | 0.0765028736186224 |
>>> 0.00263051601542076
>>> 30.4726043383638 | 30.407477679772 | 0.0651266585918009 |
>>> 0.00214179746434954
>>> 33.3089494734479 | 33.2231927324098 | 0.085756741038054 |
>>> 0.00258123118174602
>>> 54.5278744382593 | 54.5740236709768 | -0.0461492327175321 |
>>> -0.000845626355054244
>>> 56.6270596077484 | 56.4794616931023 | 0.147597914646141 |
>>> 0.00261330243280571
>>> 58.0564235524421 | 57.9072919817022 | 0.149131570739875 |
>>> 0.00257535045477517
>>> 61.5962238336604 | 61.6609971505153 | -0.0647733168549323 |
>>> -0.00105047468980788
>>> 61.7015675105702 | 61.5433341315128 | 0.158233379057449 |
>>> 0.00257108883180295
>>> 67.6094786823676 | 67.4707740811243 | 0.138704601243305 |
>>> 0.00205577308297266
>>> 68.2569872101138 | 68.0830690889332 | 0.173918121180577 |
>>> 0.00255449884248604
>>> 68.4943435865133 | 68.5554249222873 | -0.0610813357739914 |
>>> -0.000890977422184046
>>> 68.5746705524887 | 68.4885568487924 | 0.0861137036962845 |
>>> 0.00125734440406453
>>> 68.6758026445452 | 68.7123761613873 | -0.0365735168421395 |
>>> -0.000532269714501474
>>> 73.4229241308488 | 73.4212994751178 | 0.00162465573099269 |
>>> 2.21278531244639e-05
>>> 79.4484754792361 | 79.4536134385929 | -0.00513795935687256 |
>>> -6.46661509088383e-05
>>> 85.4392924899187 | 85.3402382287158 | 0.0990542612029799 |
>>> 0.00116069820355446
>>> 85.4539811995932 | 85.3919394786419 | 0.0620417209512425 |
>>> 0.00072655242789936
>>> 93.5788665631846 | 93.4985937971677 | 0.0802727660169325 |
>>> 0.000858545169043645
>>> 96.3199573238008 | 96.1797387047942 | 0.14021861900666 |
>>> 0.00145788105577033
>>> 101.328501281213 | 101.062654489096 | 0.265846792116648 |
>>> 0.00263051463926598
>>> 101.649559586565 | 101.502533562595 | 0.14702602397027 |
>>> 0.00144849609965254
>>> 108.809850830453 | 108.894277925073 | -0.0844270946195422 |
>>> -0.000775312497848917
>>> 109.397307465226 | 109.316521134613 | 0.0807863306121561 |
>>> 0.000739013003466101
>>> 110.654864554623 | 110.763015546595 | -0.108150991971058 |
>>> -0.000976417908426867
>>> 113.60376179349 | 113.561772904965 | 0.0419888885251396 |
>>> 0.000369744919007898
>>> 114.121155128581 | 113.828085749691 | 0.293069378889427 |
>>> 0.00257466667351227
>>> 114.310532244975 | 114.431988777869 | -0.121456532893603 |
>>> -0.00106138619271374
>>> 115.797340494535 | 115.877511025684 | -0.0801705311490082 |
>>> -0.000691855826375479
>>> 116.509315790761 | 116.204507950436 | 0.304807840325097 |
>>> 0.00262302939620126
>>> 116.944936442573 | 116.776885086999 | 0.168051355574235 |
>>> 0.00143908064895751
>>> 118.802848975488 | 118.599760910854 | 0.203088064634358 |
>>> 0.00171238173732078
>>> 124.752683002401 | 124.793829377275 | -0.0411463748743159 |
>>> -0.000329714819071083
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
