[postgis-devel] [postgis-users] Geog/Geom Hack
Paragon Corporation lr at pcorp.us
Sat Oct 31 12:40:27 PDT 2009
Jose,
For what its worth, I think the ST_Dwithin for geography takes care of the
ST_Intersects case nicely.  And that for example to me would be a no brainer
overload for ST_Intersects. It will be slower than the geometry
ST_Intersects, but would give the right answer.
The ST_Intersection example also brings up the point of what if the
projected srid you calculate to be the best for each geometry is different?
Or I suppose you would take both into consideration and figure out based on
area or something.  Though that would still not be quite right.
I'm thinking these things have to be analyzed on a per function basis
(rather than a sweeping answer of Yes lets overload everything people
commonly use).
So Paul -- what functions exactly did you have in mind?
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Jose
Carlos Martinez Llario
Sent: Saturday, October 31, 2009 2:17 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] [postgis-devel] Geog/Geom Hack
Hi all,
Talking about this topics..maybe I can help a little bit to some users that
do not have clear this problem and then they can help about the topic you
are talking about the functions names, etc.
Lets get the intersection of two lines that use a geographic coordinate
system (GCS), this case: epsg 4230
The result 1) is the normal PostGIS behavior. But the point: POINT(-1.5
40) is a wrong result from a cartographic point of view (but if we use a GCS
then we are talking about cartography right?).
The result 2) (we transform the GCS to a Projected reference system valid
according to the study area (ED50UTM 30N -> EPSG 23030)  and of course using
the same ellipsoid (4230): This POINT(-1.50026115912186
40.0157573310178) has a little error but it is much better approach that 1)
3)
The perfect result would be to calculate the two geodetic lines and to
intersect them directly in 4230 but this is much more complicated.
I think PostGIS should avoid using the first behavior (I do not think the
result 1 is acceptable) and at least to transform to a correct Projected
coordinate system. This task can be done automatically by checking the SRID
and finding out if it corresponds to a GCS, that case just transform the
data  . Of course, still remain the tolerance problem that I tried to
explain in the previous post.
1)
sp3=# select st_asewkt(st_intersection(l0,l1)) from (select st_geomfromtext
('SRID=4230;LINESTRING (-2 39, -1 41)') as l0, st_geomfromtext
('SRID=4230;LINESTRING (-1 39, -2 41)') as l1) as foo;
        st_asewkt
 SRID=4230;POINT(-1.5 40)
2)
sp3=# select st_asewkt(st_transform (st_intersection(l0t, l1t),4230)) from
(select st_transform (l0,23030) as l0t, st_transform(l1,23030) as l1t from
(select st_geomfromtext ('SRID=4230;LINESTRING (-2 39, -1 41)') as l0,
st_geomfromtext ('SRID=4230;LINESTRING (-1 39, -2 41)') as l1) as
foo) as foo;
                      st_asewkt
 SRID=4230;POINT(-1.50026115912186 40.0157573310178)
(1 row)
Cheers,
Jose
Jose Carlos Martinez Llario wrote:
> Thanks a lot Regina as you said it can be so confusing for users.
> I understood now the problem you guys are talking about.
> But I would like to go back again to the geodetic problem with not
> trivial method (ST_Intersects..., ST_Intersection.., etc.) I am
> reading the OGC 06-103r3 now..and for example OGC says in buffer:
> "Becaose of the limitations of linear interpolation, there will often
> be some relatively small error in this distance"
> They extends too this comment in general to any geometry operation so
> they are assuming that
> So I think they admit small errors (I do not how big..), anyways they
> talk just about LINEAR interpolation. Maybe the OGC didnt think a lot
> about geographic coordinates  when they wrote this specifications or
> maybe they are working in other specifications right now...no idea..
> Anyways if PostGIS transforms the coordinates from geographic to some
> projection before calling GEOS..then I think PostGIS/GEOS should use
> some coordinate tolerance inside the spatial operators and predicates,
> otherwise geometries that intersect, overlap, etc in the real world
> (real world is the ellipsoid or at least sphere) are not going to
> intersect, overlap,etc. in projected coordinates.
> Thanx,
> Best,
> Jose
> Paragon Corporation wrote:
>> Jose,
>> Paul can answer this better than I can.
>> right now the functions we have published for geodetic (ST_Length,
>> ST_Distance, AT_Area etc) do not use shortest line along a plane like
>> GEOS/JTS or current PostGIS distance etc. -- they are genuinely
>> measuring along a sphere/spheroid.
>> So the only issue we are talking about as you said is the cases where
>> we don't have a true geodetic answer for right now.
>> Paul's approach is to find the best spatial ref for it (whatever that
>> means?) -- transform it to that and then do the JTS/GEOS operations
>> and to pass this off as a correct answer.
>> My point is yes that's generally the right thing to do, but not
>> always - it becomes wrong depending on how big of a thing you are
>> talking about (and the both good and bad thing about geography is
>> that you can be talking about bigger things than you can easily with
>> a correct planar)  .  So while having these functions makes peoples
>> lives easier -- it also makes them difficult, because now you can't
>> distinguish the really good functions we have designed specifically
>> for sphere/spheroid from these hackish estimates. No novice or
>> advanced user would be able to do this without constantly referring
>> to the docs. How relevant this is to know is my question?
>> Thus came the other solution of just naming them differently that
>> Nicklas proposed so one can tell by the name that these are doing
>> some questionable (and possibly costly) things behind the scenes.
>> Thanks,
>> Regina
>> Sent: Saturday, October 31, 2009 12:34 PM
>> Hi everyone,
>> Maybe I did not understand all the chat about Geographic coordinates
>> but if you guys are planning to use geographic coordinates in PostGIS
>> in a wide way then what is going to happen with all the spatial
>> predicates
>> (DE9IM) and the spatial operators based on GEOS/JTS?
>> Please correct me if I am wrong but I think GEOS/JTS are based on
>> 'the shortest line between 2 points is a line so they are using
>> lineal interpolation' and not a geodesic line (sphere or ellipsoid)
>> as we need to work with geographic coordinates. Theses libraries
>> should be rewritten taking into account this fact, dont you think
>> so?..In fact right now if you intersect two lines with GEOS/JTS
>> (geographic
>> coordinates) the result is wrong (even if  GEOS had a sphere approach
>> since it would keep being wrong in rigorous point of view).
>> The approach about projecting the geographic coordinates before
>> calling GEOS to a projection with the smallest errors and choosing
>> the right type (equivalent projections, conforming projection) could
>> be the 'only'
>> approach now?
>> Thanks,
>>> Nicklas and Paul,
>>> Yap that's the main point.  To add
>>> I'm not really in disagreement with Paul.  I see his point too.  I'm
>>> just prodding him to think about all his use cases a little more
>>> because I don't feel he has.
>>> My feelings to sum up
>>> 1) We have not thought about the complete ramifications of this hack
>>> and I'm really concerned about the novice that transitions to an
>>> expert rather than just getting them hooked on PostGIS.  Perhaps I'm
>>> being overly silly with that and even said, Paul's approach might be
>>> an easier to transition solution.
>>> 2) My concern is the penalty of putting it in and having to take it
>>> out later might be very great (both from a code, testing,  as well
>>> as a mindset perspective).  I just feel it needs more thought and
>>> testing and really if we want to make our December deadline, I don't
>>> want it rushed in so lightly.
>>> Unless of course Paul -- you want to wait till January or February
>>> to release 1.5?
>>> Now the ST_Max_Distance is a separate issue.  I would put in the
>>> ST_ConvexHull hack in place.  The reason being is that it just
>>> improves performance any way I can think you slice it and an
>>> experienced user would do exactly the same thing always and when you
>>> finally incorporate it into the core function,  there is no change
>>> in existing code just a speed improvement.  So to me its basically
>>> our ST_DWithin hack -- a very tried and trued obvious answer.  Its
>>> an implementation detail with no clear leaky effects.
>>> With that said, there are some clear functions in geometry that are
>>> safe to put a geography cover over.  Those ones where there is
>>> clearly only one answer and don't involve transformation.
>>> like ST_X, ST_Y etc.  That don't require transformation so no screw
>>> up in data.  Also observe that even the geometry(geography .... in
>>> these there is no penalty becuase the geometry/geography isn't
>>> changing so the planner can cache the geometry to geography
>>> conversion.  The ST_Transformation ones however, the
>>> geometry/geography is changing slightly at each step since
>>> ST_Tranformation is a lossy operation so you are not only incurring
>>> overhead (because these answers can't be cached), but also adding in
>>> extra errors .
>>> To me this is a bleeding abstraction and that is the main reason I
>>> don't like it.
>>> So getting back to you Paul,
>>> What functions exactly are you planning to put a veil over?
>>> ST_Buffer well that one is used so much and is not as exact anyway
>>> that I suppose I can grudgingly accept that as okay.
>>> Thanks,
>>> Regina
>>> *From:* postgis-devel-bounces at postgis.refractions.net
>>> [mailto:postgis-devel-bounces at postgis.refractions.net] *On Behalf Of
>>> *nicklas.aven at jordogskog.no
>>> *Sent:* Saturday, October 31, 2009 10:04 AM
>>> *To:* PostGIS Development Discussion
>>> *Subject:* Re: [postgis-devel] Geog/Geom Hack
>>> Hallo
>>> I can see the points from both of you. I think the most important
>>> argument from you Regina is that it is not transparent enough. A
>>> skillfull user trying postgis might be disapointed when realizing
>>> that the nested functions caused an unnecessary big rounding-error.
>>> But if it is obvious that it is a "special" function at least for
>>> the experienced user knowing about common function-names I don't
>>> think it is a big problem and might work as an easy shortcut at
>>> least during the process of learning.
>>> As I understand it this could be a solution for using many functions
>>> against geography so, why not  note it in the function name like:
>>> ST_tBuffer for transformed buffer. Then when time is to introduse a
>>> "real" variant of the function they can coexist and it will not
>>> change the bahavior inside an application without someone
>>> consciously changes
>>> the function name and remove the t.
>>> the t would be independent of geography-geometry in semantics and
>>> just indicate that it is a lower-precision variant. I fit was
>>> commonly used it would work as a warning to experienced users.
>>> I have a similar question about st_max_distance. The function gets
>>> very much more effective when ran together with convexhull. I saw
>>> the trick in ST_MinimumBoundingCircle and id makes a big difference
>>> to do :
>>> st_max_distance(st_convexhull(the_geom)) instead of just
>>> st_max_distance(the_geom).
>>> The question is: Should that be put in the sql-function?
>>> My opinion now is that we just tell about it in the documentation
>>> and aims at doing that trick internally in C in the future. Maybe
>>> together with moving the whole convexhull to postgis-native from
>>> geos. It didn't look that impossible fromthe JTS-code.
>>> /Nicklas
>>> 2009-10-31 Paul Ramsey wrote:
>>> I still think I'm right :) Honestly, I've got to a lot of trouble to
>>>> make this stuff for newbies, and I don't think "learn how it works"
>>>> is the right answer for them. They had that option before, but
>>>> taking GIS
>>>> 101 is not an option for these people, they need something that
>>>> "just works". It's easier to teach the experienced people the
>>>> pitfalls than the inexperienced people the basics.
>>>> BTW, I just upgraded distance_sphere and distance_spheroid to be as
>>>> powerful (handling point/line/polygon) as the geography variants,
>>>> removing excuses for transforming geometries into geographies for
>>>> processing purposes.
>>>> P.
>>>> On Fri, Oct 30, 2009 at 9:15 PM, Paragon Corporation wrote:
>>>>> Paul,
>>>>> For what its worth, here is another reason why I don't like this
>>> idea and I
>>>>> think we should at least think about its ramifications more so
>>> should put it
>>>>> off for consideration until 2.0.
>>>>> In geometry processing, its common practice to apply a lot of
>>> functions in
>>>>> succession
>>>>> process1(process2(process3(geometry/geography)
>>>>> With your hackish approach -- the unsuspecting novice user will be
>>> incurring
>>>>> a lot of transformation rounding errors with each process
>>>>> The advanced user, won't know if this is okay or not -- because
>>> they can't
>>>>> tell by looking at the function call the hidden transformations
>>> going on.
>>>>> If these did not exist, they would transform once before the
>>> processes and
>>>>> once after) and incurr much less penalty
>>>>> But if they both exist, they will treat them as being on equal
>>>>> footing
>>>>> ST_Buffer(geometry)  and ST_Buffer(geography)
>>>>> So your approach while well-meaning gives a questionable benefit
>>>>> to
>>> novices
>>>>> and is putting experienced users at a disadvantage.
>>>>> Thanks,
>>>>> Regina
>>>>> From: postgis-devel-bounces at postgis.refractions.net
>>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf
>>>>> Of
>>> Paragon
>>>>> Corporation
>>>>> Sent: Friday, October 30, 2009 11:54 PM
>>>>> To: 'PostGIS Development Discussion'
>>>>> Cc: 'PostGIS Users Discussion'
>>>>> Subject: Re: [postgis-devel] Geog/Geom Hack
>>>>> Paul,
>>>>> I suppose we can't just put this decision off till 2.0.  Isn't
>>>>> this
>>> a bit of
>>>>> scope creep?  I'm not absolutely sure which way is better, but I
>>> know the
>>>>> cost of rolling back the change is more.
>>>>> If you are going to do this, how many functions are you planning
>>>>> to
>>> do this
>>>>> for?
>>>>> I'm cc'ing the postgis users group too to get more of an opinion
>>>>> on
>>> this
>>>>> topic.
>>>>> So the question is it it a good idea to introduce a hack that
>>> transforms a
>>>>> geography into what we call BestSRID to perform geometry
>>>>> operations
>>> on and
>>>>> then transform back.  My concern is that this is a silent
>>>>> operation
>>> that
>>>>> gives the impression that these functions are natively done in
>>>>> spheroid space just for the benefit of  catering to less technical
>> users.
>>> http://trac.osgeo.org/postgis/browser/trunk/postgis/geography.sql.in
>>> .c
>>> #L541
>>>>> So you can't really tell by looking the penalty
>>>>> Main examples of this as shown for ST_Buffer
>>>>> CREATE OR REPLACE FUNCTION _ST_BestSRID(geography, geography)
>>>>> 530         RETURNS integer
>>>>> 531         AS 'MODULE_PATHNAME','geography_bestsrid'
>>>>> 532         LANGUAGE 'C' IMMUTABLE STRICT;
>>>>> 533
>>>>> 534 -- Availability: 1.5.0
>>>>> 535 CREATE OR REPLACE FUNCTION _ST_BestSRID(geography)
>>>>> 536         RETURNS integer
>>>>> 537         AS 'SELECT _ST_BestSRID($1,$1)'
>>>>> 538         LANGUAGE 'SQL' IMMUTABLE STRICT;
>>>>> 539
>>>>> 540 -- Availability: 1.5.0
>>>>> 541 CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8)
>>>>> 542         RETURNS geography
>>>>> 543         AS 'SELECT
>>>>> geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1),
>>>>> _ST_BestSRID($1)), $2), 4326))'
>>>>> 544         LANGUAGE 'SQL' IMMUTABLE STRICT;
>>>>> 545
>>>>> Thanks,
>>>>> Regina
>>>>> Of
>>> Paul
>>>>> Ramsey
>>>>> Sent: Friday, October 30, 2009 11:07 PM
>>>>> To: PostGIS Development Discussion
>>>>> We're going to have to agree to disagree on this one, Regina.
>>> Catering to
>>>>> the less technical users is what this exercise is all about, to my
>>> mind, and
>>>>> that includes allowing easy flipping into geometry for
>>>>> calculations
>>> that
>>>>> aren't supported in geography yet. Oracle does this too.
>>>>> What do other folks think?
>>>>> P.
>>>>> On Fri, Oct 30, 2009 at 7:06 PM, Paragon Corporation wrote:
>>>>>> Paul,
>>>>>> Hmm when I am comparing distance of two geometries in different
>>>>>> spatial refs which I do a lot.
>>>>>> I still don't like the hack even if you disregard the above or if
>>>>>> you must hack -- don't give it the same name as the non-hacked
>> functions.
>>>>>> the whole idea of picking BestSRID for a person to cater to less
>>>>>> technical users I find extremely annoying as I can think of 20
>>>>>> "BestSRID" depending on what I am doing.  If they get to that
>>>>>> level of sophistication, I would rather have them think a little
>>>>>> more  and understand the implications of those decisions.
>>>>>> We must learn to crawl before we can learn to walk,because
>>>>>> walking without understanding will just get you into trouble in
>>>>>> the long run.
>>>>>>  Thanks,
>>>>>> Regina
>>>>>> Of Paul Ramsey
>>>>>> Sent: Friday, October 30, 2009 9:47 PM
>>>>>> You *can*, but I strongly doubt you *will*. Because there's
>>>>>> nothing in geography that isn't already in geometry. So you as a
>>>>>> primary geometry user are going to have no working need to cast
>>>>>> things
>> to geography.
>>>>>> On the other hand, the very first question from users of
>>>>>> geography will be "how can I access ?" So having a relatively
>>>>>> full set of functions already available in geography makes sense
>>>>>> to me, even if they are hacked in with a planar trick.
>>>>>> P.
>>>>>> On Fri, Oct 30, 2009 at 5:46 PM, Paragon Corporation wrote:
>>>>>>> Paul,
>>>>>>> I can put a functional geography index on can't I and take
>>>>>>> advantage of geography index bindings?
>>>>>>> Lets say I have a large network of tables broken out by region
>>>>>>> so I know a specific table has one srid.
>>>>>>> For many queries, I may go to that table directly or if I'm
>>>>>>> doing single geometry processing, really don't care what srid as
>>>>>>> long as its in utm or whatever - so I can use the full power of
>>>>>>> GEOS.
>>>>>>> For my across the board distance checks and so forth, I would
>>>>>>> want to use geography and I could use a geography index if I put
>>>>>>> a functional geography index on my geometry correct?  Though
>>>>>>> that needs some more
>>>>>> testing.
>>>>>>> So in short if 90% of my workload involves geometry processing,
>>>>>>> I will want to keep my data in geometry
>>>>>>> But the 10% I would want to convert to geography on the fly.
>>>>>>> Thanks,
>>>>>>> Regina
>>>>>>> Of Paul Ramsey
>>>>>>> Sent: Friday, October 30, 2009 8:34 PM
>>>>>>> I'm not sure I understand why you would ever convert a geometry
>>>>>>> to a geography as part of a query on a geometry table. I fully
>>>>>>> expect geography to be used as a storage type, because of the
>>>>>>> utility of having the correct spherical indexes, which are not
>>>>>>> available when you're just converting in via a cast. Since
>>>>>>> there's no functions available on geography that are not already
>>>>>>> available on geometry, why would you ever do a
>>>>>>> geometry->geography cast unless you are (a) testing geography or
>>>>>>> (b) bulk converting a table into geography for
>>>>>> storage in that type.
>>>>>>> P.
>>>>>>> On Fri, Oct 30, 2009 at 5:24 PM, Paragon Corporation wrote:
>>>>>>>> Paul,
>>>>>>>> I would rather you didn't for 2 reasons
>>>>>>>> 1) I'm lazy and for each of these things we'd have to apply the
>>>>>>>> text additional function proto hack to prevent from it breaking
>> geometry.
>>>>>>>> which we will probably end up taking out anyway.
>>>>>>>> 2) I don't like the hiddenness of it since it becomes
>>>>>>>> especially annoying if you have your native in geometry and you
>>>>>>>> are converting to geography for a special usecase, then you end
>>>>>>>> up with a slower implementation
>>>>>>>> as you would really end up doing accidentally
>>>>>>>> geometry -> geography -> geometry ->operation (and why do I
>>>>>>>> want my calcs done in UTM?)
>>>>>>>> Instead of the more efficient
>>>>>>>> geometry -> operation
>>>>>>>> Thanks,
>>>>>>>> Regina
>>>>>>>> Behalf Of Paul Ramsey
>>>>>>>> Sent: Friday, October 30, 2009 8:16 PM
>>>>>>>> Subject: [postgis-devel] Geog/Geom Hack
>>>>>>>> I'm interested to know what the general opinion is of the trick
>>>>>>>> I've used on
>>>>>>>> ST_Buffer(geography):
>>> http://trac.osgeo.org/postgis/browser/trunk/postgis/geography.sql.in.
>>>>>>>> c
>>>>>>>> #L541
>>>>>>>> I ask because I could apply the same idea to the larger suite
>>>>>>>> of OGC SFSQL predicates before release. Is half-a-loaf better
>>>>>>>> than no loaf in
>>>>>>> this case?
>>>>>>>> (Note that there will be failure cases for really large
>>>>>>>> geometry, like a polygon of "Asia" or "Russia" that have
>>>>>>>> polygons over the
>>>>>>>> dateline.)
>>>>>>>> P.
>>>>>>>> _______________________________________________
>>>>>>>> postgis-devel mailing list
>>>>>>>> postgis-devel at postgis.refractions.net
>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> José Carlos Martínez Llario
>> Producción Cartográfica y SIG.
>> Dpto. Ingeniería Cartográfica.
>> Univ. Politécnica de Valencia.
>> E-mail: jomarlla at cgf.upv.es
>> Telf: 963877007 ext. 75599
