[postgis-devel] [PostGIS] #202: upgrade issues
Paragon Corporation
lr at pcorp.us
Tue Sep 1 12:51:52 PDT 2009
Strk,
To clarify. Its always doing a create replace of all functions.
The issue I was trying to resolve are cases where you can't do a create
replace
1) Creating of casts -- we happened to miss one in our 1.4 upgrade script
for example -- so this version will do something like a
SELECT postgis_create('CAST', 'geometry');
Which basically creates the casts needed for geometry if each does not exist
2) Create aggregates -- we always do a drop if exists and create aggregate
(from 1.4 moving forward even for new install). I left that as is but
pulled that into the
postgis_create function and the related functions that go with it.
So create aggregate statements get replaced with a
SELECT postgis_create('AGGREGATE', 'makeline'); //which creates
ST_MakeLine, MakeLine aggs etc.
The reason I pushed it into the postgis_create even though it is doing the
same thing, is that dropping an aggregate is annoying and at some point
would like to do a conditional drop. That's one of the reasons I don't like
pointless upgrades. At some point I would like to have it check the version
being upgraded and conditionally drop if it has changed since then. The
reason I don't like the DROP AGGRE approach we are currently using is that
for example I have some databases that use aggregates in views. In such
cases the upgrade script fails. Why should I have to rebuild my aggregate
views if I am moving from 1.4 to 1.5 or 1.4 to 1.4.1 for example.
3) Same issue with types, we kind of hard code the types we have changed, in
the postgis_upgrade.pl, but if I am going from 1.4 to 1.4.1
box3d_extent already exists, so upgrade fails. So by doing a
SELECT postgis_create('TYPE', 'box3d_extent');
It will only create the type if it doesn't exist in the database already.
Right now as a side effect, the postgis.sql I am proposing is a one size
fits all (it works for both upgrade and new install). Mark had issue with
that, and I'm okay with having two -- and each having a slightly different
version of postgis_create plpgsql function if need be.
In the end in either way -- the postgis_create function is dropped when the
script is done.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of strk
Sent: Tuesday, September 01, 2009 3:17 PM
To: PostGIS
Cc: postgis-devel at postgis.refractions.net
Subject: Re: [postgis-devel] [PostGIS] #202: upgrade issues
On Tue, Sep 01, 2009 at 04:05:36PM -0000, PostGIS wrote:
> This does what I described above, but I tested it by upgrading a
> postgis
> 1.4 to 1.5 and creating a postgis 1.5 fresh. Have to find my old 1.3
> data to test upgrading, but should work since it recreates
> aggregates, but only creates types if they don't already exist.
What if they exist but have been obsoleted by later "bug-fixed" ones ?
That's the point of a "CREATE OR REPLACE" call after all.
--strk;
Free GIS & Flash consultant/developer () ASCII Ribbon Campaign
http://foo.keybit.net/~strk/services.html /\ Keep it simple!
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
