[postgis-devel] ST_Line_Substring
Paul Ramsey pramsey at cleverelephant.ca
Wed Sep 9 14:27:59 PDT 2009
Thanks Nicklas, that's a nice write-up. In future, remember to attach
in open formats, like PDF or OpenOffice. And now that I see your
implementation is a bolt-on enhancement ot distance calculations
rather than a replacement I feel more comfortable with it. It seems
like you could have some degenerate conditions if the bbox center is
quite a ways outside the actual polygon boundary, though, have you
tested that?
Another approach to the problem would be to build an internal index of
the edges of both polygons, then traverse that index. It would have
the advantage of being cacheable and more general (works for all
cases) but would probably not have nearly the real-world improvement
your heuristic has.
I'm interested to hear what a real geometer thinks of your approach, I
wonder if Martin would comment?
P.
On Wed, Sep 9, 2009 at 1:32 PM, <nicklas.aven at jordogskog.no> wrote:
> thanks
> about the distance-calculations don't miss the dist.doc in ticket #231.
> That might save you some time to see the idea behind the new
> distance-calculation of polygons and linestrings that don't have
> intersecting bounding boxes.
> /Nicklas
> 2009-09-09 Paul Ramsey wrote:
> Niklas,
>>There are at least three different implementations of line substring
>>hanging around, a couple that are bound to the old functions and one I
>>did for the elevationbetween functions. The whole conjunction calls
>>out for a cleaning and consolidation, frankly, but I've been leaving
>>it alone on the basis of not touching things that are working.
>>Attach your patch for 3D to a ticket so it doesn't get lost. I've got
>>reviewing your distance ticket on my list too so don't give up hope on
>>that.
>>P.
>>On Sun, Aug 30, 2009 at 1:17 PM, wrote:
>>> The function ST_Line_Substring is some mixture between 2D and 3D. It
>>> preserves the z-value but don't use it in calculation. The documentation
>>> describes this but the note that the function supports 3D I think is
>>> false.
>>> Why not make it real 3D so it considers the third dimmension in the
>>> calculation.
>>> Now this query:
>>> select st_asewkt(ST_Line_Substring(the_geom,0.2, 0.8))
>>>  from
>>> (SELECT ST_GeomFromEWKT('SRID=4269;LINESTRING(1 1 1,1 1 3, 1 1 5, 1 1
>>> 8)')
>>> as the_geom ) a;
>>> gives the little bit strange result:
>>> "SRID=4269;LINESTRING(1 1 3,1 1 5)"
>>> I think t would be much better to make it fully 3D-supportive. Then the
>>> result of this query is:
>>> "SRID=4269;LINESTRING(1 1 2.4,1 1 3,1 1 5,1 1 6.6)"
>>> I have attached a patch that makes this.
>>> The reason I started to look at this was that I wanted a function that
>>> takes
>>> distances instead of fraction of the total length.
>>> I hve a working finction that takes the startdistance and end-distance
>>> from
>>> the start of the line to pull out the substring-line. In some cases that
>>> is
>>> more straight on than going via the fractions. Should I post it or will
>>> there be to many functions too little difference?
>>> The question is if I should put effort in writing the documentation and
>>> regression-tests.
>>> Greetings
>>> Nicklas
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
