[postgis-devel] [PostGIS] #179: ST_MakeLine and ST_MakeLine_Garry crash server with null arrays
trac at osgeo.org
Sun Sep 13 17:32:10 PDT 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: postgis 1.3.7
Component: postgis | Version: 1.3.X
Resolution: | Keywords:
Comment (by robe):
Nicklas,
Ah indeed you are right. Its still broken in 1.4 and 1.5.
Well the funny thing is my 1.4.1SVN I can't get it to break, but I was
able to get it to break on 1.4.0 RTM and my 1.5 compiled from 8/5. So
maybe Mark fixed for the aggs (or forgot about ST_MakeLine array version)
Can you get it to break against 1.4 branch?
I presume I must have missed this because it doesn't always break. Just
sometimes. and probably the times I was testing it it was behaving.
Regarding the note about STRICT. I don't think its the aggregate we mark
as strict, but the state function. pgis_geometry_accum_transfn (for 1.4+)
and for (1.3+) -- st_geom_accum and that should unless I am missing
something fix the aggregate issue.
To fix the ST_Unite... array version -- we would mark that as STRICT as
well. That however I think would just prevent people from using it with
NULL arrays (or hmm arrays that contain NULL). Not sure which. Haven't
tested to tel. It wouldn't be ideal, but I presume if 1.3 is a hard fix
its better to get an error and the correct answer than to have a crashing
server. For 1.3 those array functions are not documented. So would just
be abusive people like me looking behind the hood using it. The world
needs to be protected from people like me of course :).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/179#comment:18>
