[postgis-devel] Geography on Trunk
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Sep 14 03:56:33 PDT 2009
Paul Ramsey wrote:
> Devs,
> The geography work has now passed a few milestones, in terms of having
> instantiable objects, index bindings and simple create/serialize
> functions. The work in the sandbox has also proven that the new type
> will not require re-working of the existing functionality and can
> function as bolt-on code next to the old code. The primary reason for
> working in a sandbox was to have the freedom to break core code if
> necessary, and it turns out, that was not necessary.
> So, I would like to bring the geography sandbox back into trunk. There
> are no technical implications that I can see. There is only one
> procedural implication, which is that once geography is in, a 1.5
> release will probably end up waiting until geography is ready for
> general release. The work is being done under contract however, and a
> numbered release is supposed to come out before Christmas, so if
> anything we would be accelerating the natural release cycle.
> Thoughts?
> Paul
Okay - I think we're done. Most of the merge was handled automatically,
with just a few manual clean-ups required. So any mistakes in the
current trunk are probably mine ;)
Please make sure that you check out trunk from fresh, or do an "svn up"
before continuing to develop on trunk or any of the geodetic code.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
