[postgis-devel] [PostGIS] #246: Platform differences when performing a union
PostGIS trac at osgeo.org
Mon Sep 14 05:56:48 PDT 2009
  Reporter:  lighthousej  |       Owner:  pramsey
      Type:  defect       |      Status:  new
  Priority:  medium       |   Milestone:  postgis 1.4.1
 Component:  postgis      |     Version:  1.4.X
Resolution:               |    Keywords:
Changes (by robe):
  * milestone:  postgis 1.5.0 => postgis 1.4.1
Comment:
 Can you try the GEOS 3.2SVN packaged in the Windows experimental (PostGIS
 1.5SVN build).  You just need to replace the 2 geos binary files. It
 should work just fine with your current PostGIS 1.4
 http://postgis.refractions.net/download/windows/experimental.php
 It could have been an issue that affected windows but not Linux because of
 some rounding differences.  Others who have tried the GEOS 3.2SVN build
 for windows have had good success with these topological exception cases
 where the geometries are valid.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/246#comment:1>
