[postgis-devel] [PostGIS] #249: Geography cunit test fails on OpenSuse 10.3
PostGIS trac at osgeo.org
Fri Sep 18 04:21:40 PDT 2009
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  postgis 1.5.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Test: test_gserialized_get_gbox_geocentric() ...
 LINESTRING(-120.0 -5.0,60.0 80.0)
 GBOX((-0.49809734904587255,-0.862729915662821,-0.08715574274765817),(0.08682408883346522,0.15038373318043535,1.0))
 line 41: diff 0.00519813908
 FAILED
     1. cu_geodetic.c:160  -
 CU_ASSERT_DOUBLE_EQUAL(gbox->xmin,gbox_good->xmin,0.000001)
 I'll have to check on my other OpenSuse.  Check passes under mingW
 install.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/249>
