[postgis-devel] [PostGIS] #250: Trunk doesn't compile under MingW because of regex
PostGIS trac at osgeo.org
Fri Sep 18 07:12:10 PDT 2009
  Reporter:  robe     |       Owner:  robe
      Type:  defect   |      Status:  assigned
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Changes (by robe):
  * owner:  pramsey => robe
  * status:  new => assigned
Comment:
 Fixed at r4511.  I'm going to leave open since I've only tested against
 OpenSuse and mingW.  Paul, Mark, and Kevin -- can you verify you can still
 compile.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/250#comment:1>
