[postgis-devel] [PostGIS] #250: Trunk doesn't compile under MingW because of regex
trac at osgeo.org
Tue Sep 22 04:43:22 PDT 2009
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Well - I can compile under MingW and it passes the cunit tests, but fails
my torture test.
Can't do this anymore:
CREATE TABLE pgis_geoggarden (gid serial, the_geog geography(POINT,
4326));
Gives me a "Invalid geometry type modifier: point"
Though I can do this yee pee:
CREATE TABLE gtable ( id integer primary key, geog geography );
Ticket URL: <http://trac.osgeo.org/postgis/ticket/250#comment:5>
