[postgis-devel] CREATE LANGUAGE in postgis.sql
Kevin Neufeld kneufeld at refractions.net
Tue Sep 22 08:36:52 PDT 2009
Right.  Unfortunately, PostgreSQL doesn't have the CREATE LANGUAGE [IF NOT EXISTS] syntax yet, so it'll have to go
outside of the transaction block.
If we put the CREATE LANGUAGE command at the start of the postgis.sql file, but outside the block, then the first thing
most people will see when they install PostGIS is an ERROR message ... could cause a lot of confusion.  It also means
one can't grep the output for ERRORs when performing automatic installs.
... unless someone can thing of a cleaver way to query the pg_language table for the existence of 'plpgsql' and execute
the create language statement appropriately ...
-- Kevin
Mark Cave-Ayland wrote:
> Paul Ramsey wrote:
>> In answer to me, it's an ERROR so the transaction block will fail
>> unless we do it outside the block.
> Yeah, that was along the lines of what I was thinking...
> ATB,
> Mark.
