[postgis-devel] [PostGIS] #252: Text autocasting behavior of geography is breaking geometry functionality
PostGIS trac at osgeo.org
Thu Sep 24 03:59:34 PDT 2009
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 It appears there is one other solution besides renaming functions and that
 is to declare yet another function that in the face of unknown trumps the
 other functions.
 After studying the docs, it appears to me that the text/varcahr datatype
 is hard-wired to rank higher as an appropriate CAST for unknown than any
 other data type (or at least in 8.4).
 http://www.postgresql.org/docs/8.4/interactive/typeconv-func.html (see
 bullet 4 item d)
 -- have to test 8.3 though docs of 8.3 suggest the same)
 The below appears to solve the problem (for ST_AsBinary and I presume we
 could do the same for others where we will have name clashes).  I've only
 tested on 8.4 (not yet on 8.3).
 Alternatively we could do nothing and proclaim this is a bad habit of
 people anyway and force them to change their ways by breaking their
 malformed apps.  It might make many people mad, but they might thank us in
 the long run (or maybe not :))
 CREATE OR REPLACE FUNCTION st_asbinary(text)
   RETURNS bytea AS
 $$ SELECT st_asbinary($1::geometry);  $$
   LANGUAGE 'sql' IMMUTABLE STRICT
   COST 1;
 Does anyone see a problem with the aforementioned solution.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/252#comment:3>
