[postgis-devel] [PostGIS] #478: [wktraster] There seems to be an offset in ST_Envelope or ST_Box2D
PostGIS trac at osgeo.org
Tue Apr 6 04:11:52 PDT 2010
  Reporter:  robe       |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by jorgearevalo):
 Regina,
 Sorry, I was using OpenJump from Ubuntu 9.10 repositories. That's the old
 1.0 version. I've downloaded the last stable one (1.3.1), and now it's ok.
 I can see what you say.
 About the loader, yes, you have to specify the srid as an argument. If
 not, -1 is used. In the DEM file, for example, the srid matching with
 +proj=utm +zone=10 +ellps=clrk66 +datum=NAD27 +units=m +no_defs
 should be used, but you get -1 if don't specify the right one with --srid
 option (I suppose you did it). This could be a new ticket, I guess...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/478#comment:10>
