[postgis-devel] [PostGIS] #478: [wktraster] There seems to be an offset in ST_Envelope or ST_Box2D
PostGIS trac at osgeo.org
Tue Apr 6 08:23:39 PDT 2010
  Reporter:  robe       |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by pracine):
 I guess the clue here is the fact that ST_Box2D coordinates are encoded as
 float4 and Envelope as doubles. If I'm right, 1) the bug should appear
 only when there is many significant digits in the coordinates and 2) a
 PostGIS line geometry joining one of the two diagonals of a raster extent
 should present the same problem (Box2d should be different than the
 envelope). To verify...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/478#comment:13>
