[postgis-devel] ST_MakeEllipse
Jeff Adams
jadams at azavea.com
Wed Apr 7 05:45:42 PDT 2010
Actually the wiki is slightly out of date regarding CUnit tests
(unfortunately I don't have the time to fix it right now). The process is
slightly simpler than what's documented in the wiki (no more headers for the
test files).
The README in the unit test directory has the most up-to-date description of
how to add tests.
Jeff
On Wed, Apr 7, 2010 at 2:40 AM, Olivier Courtin <
olivier.courtin at oslandia.com> wrote:
> On Apr 7, 2010, at 7:32 AM, Poizot Emmanuel wrote:
> Hi Emmanuel.
> I developped on the current trunk version of Postgis a new function:
>> ST_MakeEllipse,
>> which create a polygon with an ellipse shape.
> Could be a nice new function ! :)
> As I'm not aware with the development process of Postgis, I wonder how I
>> can give back this dev to Postgis site.
> A way to do so, is 'just' to send on this list a patch generated with diff
> -u command.
> and also to say explicitly in your mail, the trunk revision number.
> The patch should compile without warnings,
> don't generate any errors with make check,
> and follow the style guide (http://svn.osgeo.org/postgis/trunk/STYLE)
> In a perfect world the patch should also contains
> DocBook documentation and CUnit tests:
> http://trac.osgeo.org/postgis/wiki/DevWikiDocNewFeature
> http://trac.osgeo.org/postgis/wiki/DevWikiCUnit
> But for a single function if you already provide 'clean' code,
> that's a good start ! :)
> Don't hesitate to ask any question related to this process on the list.
> Olivier
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Jeff Adams
Azavea (formerly Avencia) | T: 215.701.7717 | F: 215.925.2663
www.azavea.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100407/5f1ad1fd/attachment.html>
