[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
PostGIS trac at osgeo.org
Sat Apr 10 09:13:20 PDT 2010
 Reporter:  robe       |       Owner:  pracine
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  WKTRaster 0.1.6
Component:  wktraster  |     Version:  trunk
 Keywords:             |
 I got wktraster to compile under mingW with the GDAL extensions.
 I documented the process at
 http://trac.osgeo.org/postgis/wiki/WKTRaster/Documentation01#a2.3-CompilingandInstallingfromSources
 Unfortunately the testapi.exe crashes with errors like
 The thread 'Win32 Thread' (0x10b0) has exited with code 0 (0x0).
 Unhandled exception at 0x77c46fa3 in testapi.exe: 0xC0000005: Access
 violation reading location 0x00000003.
 First-chance exception at 0x77c46fa3 in testapi.exe: 0xC0000005: Access
 and if I install and run the following -- crashes Postgres backend
 CREATE TABLE dummy_rast(rid integer, rast raster);
 INSERT INTO dummy_rast(rid, rast)
 VALUES
 -- Raster: 5 x 5 pixels, 3 bands, PT_8BUI pixel type, NODATA = 0
 (2,  ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A' ||
 '41000000007719564100000000000000000000000000000000FFFFFFFF050005000400FDFEFDFEFEFDFEFEFDF9FAFEF'
 'EFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster);
 SELECT ST_DumpAsPolygons(rast)
 FROM dummy_rast where rid=2;
 It crashes the Postgres backend.  I'm guessing it might have the same
 issue we had with libxml #273 and as a workaround we statically compiled
 in libxml for windows.  Its not a great solution but it worked.
 I'm not quite sure how to statically compile libgdal in though.  I tried
 --enable-static but that hasn't worked.  Will fiddle with it a bit more.
 Jorge -- can you verify the above example is suppoed to work.  You said
 ST_AsDumpPolygons isn't quite ready yet so wasn't sure if maybe it crashes
 on Linux too.
 Also I didn't see an ST_Polygon functions when I enabled gdal.  Thought
 that was supposed to be there.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494>
