[postgis-devel] [PostGIS] #498: Gdal export of some files gives blank image
PostGIS trac at osgeo.org
Tue Apr 13 20:53:00 PDT 2010
 Reporter:  robe       |       Owner:  pracine
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  WKTRaster 0.1.6
Component:  wktraster  |     Version:  trunk
 Keywords:             |
 I think my mapserver problems may be related to my export issues, and I'm
 not quite sure where the problem lies.
 I tried this example from
 http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html
 C:\python25\python gdal2wktraster.py -r small_world.tif -t
 ch13.small_world -l 1 -k 40x20 -o small_world.sql -s 4326
 Then tried to export it with
 gdal_translate -of PNG PG:"host=localhost dbname=
 'wktraster_postgis15' user='postgres' password='whatever' schema='ch13'
 table=sm
 all_world" C:\small_world.png
 gdal_translate -of JPEG -band 1 PG:"host=localhost dbname=
 table=sm
 all_world" C:\small_world_bw.jpg
 And those both work fine, but if I try to do the same thing with the
 PostGIS elepant, I just get a blank or black screen output.
 C:\python25\python gdal2wktraster.py -r pele.png -t ch13.pele2 -l 1 -k
 40x20 -o pele2.sql
 psql -h localhost -d wktraster_postgis15 -U postgres -f pele2.sql
 table=pele2" C:\pelefromdb.png
 Just gives me a black box or blank image of the right dimensions.
 I had the same issue with a georefenced MrSID file I had converted to
 georeferenced JPEG and then loaded in, but I thought maybe it was my
 conversion statement.
 I tried on an ArcView Raster file (BIL) and exported that and that seemed
 to work fine.
 So now I'm beginning to thinks its either the pixel types or original file
 type.  Quick scan of pixel values in db look right to me well they are
 definitely all differnt numbers.
 Attached is the PostGIS elephant to test with.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/498>
