[postgis-devel] [PostGIS] #467: shp2pgsql: command line option to cope with broken strings in dbf files
PostGIS trac at osgeo.org
Thu Apr 15 03:03:20 PDT 2010
  Reporter:  agnat    |       Owner:  strk
      Type:  patch    |      Status:  assigned
  Priority:  medium   |   Milestone:  PostGIS 1.5.2
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:  shp2pgsql
Comment (by agnat):
 patch3 does not expose iconvs transliterate option on the command line
 anymore. First i thought it's a good idea to expose all error policies for
 maximum flexibility. However, on a second thought I can not come up with a
 real use-case for the transliterate policy. That's because the target
 format is always utf-8 and there really is no need to transliterate to
 utf-8.
 If anybody has a use-case that requires transliteration we can easily add
 this option back.
 Although strk already fixed things for broken utf-8 input this patch is
 still useful when dealing with non utf-8 data. For example the
 [http://www.gadm.org gadm shapefiles] contain garbled strings in windows-
 1252 encoding. To import these files and just ignore characters that don't
 have a utf-8 representation set the -C option.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/467#comment:3>
