[postgis-devel] [PostGIS] #504: shp2pgsql should rename xmin/xmax fields
PostGIS trac at osgeo.org
Fri Apr 16 14:13:20 PDT 2010
  Reporter:  pramsey      |       Owner:  pramsey
      Type:  enhancement  |      Status:  new
  Priority:  low          |   Milestone:  PostGIS 1.5.2
 Component:  postgis      |     Version:  1.5.X
Resolution:               |    Keywords:
Comment (by springmeyer):
 +1!
 Exposing the ability to configure the escape character used would also be
 a valuable thing from my perspective. Not critical at all and potentially
 not useful to 99% of users, but the basic situation is that I frequently
 use shp2pgsql to load arbitrary shapefiles into postgis, and then
 dynamically build django models (in python) from the table schema created
 by shp2pgsql. A gocha is that the _ is illegal according to django for
 field names (not sure why), so I have to batch find and rename those
 fields to remove the leading _.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/504#comment:3>
