[postgis-devel] [PostGIS] #504: shp2pgsql should rename xmin/xmax fields
PostGIS trac at osgeo.org
Sun Apr 18 05:14:34 PDT 2010
  Reporter:  pramsey      |       Owner:  pramsey
      Type:  enhancement  |      Status:  closed
  Priority:  low          |   Milestone:  PostGIS 1.5.2
 Component:  postgis      |     Version:  1.5.X
Resolution:  fixed        |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 xmin escaped as of r5566. xmax was already escaped.
 The user-defined escape char might be useful but worth a separate ticket.
 Note that in order to be symmetric any user-defined escape should be also
 reflected
 in the dumper.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/504#comment:4>
