[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
PostGIS trac at osgeo.org
Thu Apr 22 03:15:38 PDT 2010
  Reporter:  robe       |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by jorgearevalo):
 I think so. When creating a new GDALRasterBand in
 rt_raster_dump_as_wktpolygons, there was a static array to store the
 data. It was a clear error (my fault, of course, and I'm really
 sorry), that could produce access violation if the band data are
 bigger than the array size.
 Now, the memory is allocated based on the raster dimensions and the
 band datatype. Commited in r5570.
 I hope this helps...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494#comment:5>
