[postgis-devel] [PostGIS] #467: shp2pgsql: command line option to cope with broken strings in dbf files
trac at osgeo.org
Thu Apr 22 12:53:33 PDT 2010
Reporter: agnat | Owner: strk
Type: patch | Status: assigned
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Resolution: | Keywords: shp2pgsql
Comment (by agnat):
You could store anything <=255 bytes in a string field.
[http://www.clicketyclick.dk/databases/xbase/format/data_types.html#DATA_TYPES
Other sources] state that ASCII is the right encoding. However, if you say
it's common practice to use utf-8 in dbf/shapefiles (like the geofabrik
guys do) i'm happy. I'm a geo-noob, you're a committer.
I used the [http://www.gadm.org/data/gadm_v1_shp.zip world file] (475MB)
in my tests, but i guess it affects every file that uses non ascii
characters (and that has not been fixed yet). I ''think'' the strings in
the germany file are broken, too. But I have to verify that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/467#comment:6>
