[postgis-devel] [PostGIS] #467: shp2pgsql: command line option to cope with broken strings in dbf files
trac at osgeo.org
Thu Apr 22 13:16:54 PDT 2010
Reporter: agnat | Owner: strk
Type: patch | Status: assigned
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Resolution: | Keywords: shp2pgsql
Comment (by agnat):
The [http://www.gadm.org/data/shp/MLI_adm.zip Mali file] is corrupted and
a lot smaller.
$ shp2pgsql MLI_adm1.shp > /dev/null
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
Unable to convert field value "..." to UTF-8: iconv reports "Illegal byte
sequence"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/467#comment:7>
