[postgis-devel] St_Intersection on same table
Rafal Foltynski
rfolt at yahoo.com
Fri Apr 23 08:31:58 PDT 2010
I have a table with many overlying polygons. I want to create a new polygon relation from the intersection of these polygons that has two fields 1. geometry of small polygons - the result of St_Intersection() and 2. count of the number of overlying polygons that each small polygon was created from. How do I create a query to run St_Intersect on the same geometry field in one table?
For example: if I have a table with 3 polygons, 2 of them share a small area and the third polygon is disjoint, the resulting polygon relation would only have one small polygon area (shared area between two polygons) and count of 2.
Rafal
