[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
PostGIS trac at osgeo.org
Tue Apr 27 16:50:10 PDT 2010
  Reporter:  robe       |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by jorgearevalo):
 make check crashes in Linux because stricmp is not defined. That function
 doesn't need to be defined in UNIX systems. I've defined stricmp as
 strcasecmp and strincmp as strncasecmp for UNIX systems. Commited in
 r5578.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494#comment:10>
