[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
PostGIS trac at osgeo.org
Wed Apr 28 05:05:27 PDT 2010
  Reporter:  robe       |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by robe):
 One small problem.  The .sql script no longer works because its
 complaining geomval and the ST_DumpAsPolygons (ST_DumpAsPolygons is
 returning too many fields).
 It seems we are now returning srid as a column in ST_DumpAsPolygons, but
 geomval only has a geometry and pixel value.
 Why is it necessary to return srid as a column in ST_DumpAsPolgons.  This
 does not make sense to me.  It makes sense for the DumpAsWKT, but for
 ST_DumpAsPolygons, the srid should be encoded in the geometry.  So seems
 to me it should be rewritten as
         SELECT ST_GeomFromText(wktgeomval.wktGeom, wktgeomval.srid),
 wktgeomval.val,
          FROM DumpAsWKTPolygons($1, 1) AS wktgeomval;
 Instead of what it is now which is
         SELECT ST_GeomFromText(wktgeomval.wktGeom), wktgeomval.val,
         wktgeomval.srid FROM DumpAsWKTPolygons($1, 1) AS wktgeomval;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494#comment:11>
