[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
PostGIS trac at osgeo.org
Wed Apr 28 10:23:26 PDT 2010
  Reporter:  robe       |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by jorgearevalo):
 Ok, I've reproduced the error. The first checking in the C SRF function
 rt_dump_as_wktpolygons is:
 if ( (PG_NARGS() < 1 || PG_NARGS() > 2 )
 elog(ERROR, "RASTER_dumpAsWKTPolygons requires 1 or 2 args\n");
 PG_RETURN_NULL();
 I've printed PG_NARGS() and it's a big number (16297). I don't know if
 it's related with the fact the raster, the first argument, must by
 detoasted with PG_DETOAST_DATUM(PG_GETARG_DATUM(0)), and it's considered
 like "a lot" of input arguments. Has sense?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494#comment:18>
