[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
trac at osgeo.org
Fri Apr 30 04:34:52 PDT 2010
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Okay I'm getting output now. But still a couple of problems
1) Very minor -- but if I feed a raster with no bands, I get an assert
error in postgres.exe that I have less than one band. I presume this is
expected? Except it should just be a notice rather than kicking me into
visual studio debugger - well hmm I guess since we are still in alpha it
might be best to just leave as is if easier to debug.
2) This one is very strange and it seems very intermittent. Once it fails
I can't get it to work again for another 10 or so tries and then it works.
I haven't ever gotten just the inner subselect to work without doing
restrictions on val which is even more bizzarre since I can't see how the
ST_Union would ever work if the inner fails all the time. I'm running
1.5.1 so I'll upgrade to 1.5.2SVN and see if I experience any difference.
I haven't looked at the rendered image yet to veerify it looks correct.
SELECT ST_Union(geom)
FROM (SELECT (ST_DumpAsPolygons(rast)).geom
FROM ch13.pele
) As foo
This gives error
ERROR: parse error - invalid geometry
HINT: "...00,52 101,53 101,54 101,54 99,53 99))" <-- parse error at
position 64 within geometry
CONTEXT: SQL function "st_dumpaspolygons" statement 1
If I run Just the inner query
I get the same error.
I'll attach the file in a bit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494#comment:21>
