[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
PostGIS trac at osgeo.org
Fri Apr 30 05:36:53 PDT 2010
  Reporter:  robe       |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by jorgearevalo):
 Replying to [comment:21 robe]:
 > Okay I'm getting output now.  But still a couple of problems
 > 1) Very minor -- but if I feed a raster with no bands, I get an assert
 error in postgres.exe that I have less than one band.  I presume this is
 expected?  Except it should just be a notice rather than kicking me into
 visual studio debugger - well hmm I guess since we are still in alpha it
 might be best to just leave as is if easier to debug.
 Could you paste the error message and the query that caused it?
 > 2) This one is very strange and it seems very intermittent.  Once it
 fails I can't get it to work again for another 10 or so tries and then it
 works.  I haven't ever gotten just the inner subselect to work without
 doing restrictions on val which is even more bizzarre since I can't see
 how the ST_Union would ever work if the inner fails all the time.  I'm
 running 1.5.1 so I'll upgrade to 1.5.2SVN and see if I experience any
 difference.  I haven't looked at the rendered image yet to veerify it
 looks correct.
 > SELECT ST_Union(geom)
 > FROM (SELECT (ST_DumpAsPolygons(rast)).geom
 > FROM ch13.pele
 > ) As foo
 > This gives error
 > ERROR:  parse error - invalid geometry
 > HINT:  "...00,52 101,53 101,54 101,54 99,53 99))" <-- parse error at
 position 64 within geometry
 > CONTEXT:  SQL function "st_dumpaspolygons" statement 1
 > If I run Just the inner query
 > I get the same error.
 Ok, I think I know the reason, and I fixed it. Please update to r5589. I
 executed st_astext over your query and I got this:
 POLYGON((89 0,88 0,87 0,86 0,85 0,84 0,83 0,82 0,
 81 0,80 0,79 0,78 0,77 0,76 0,75 0,74 0,73 0,72 0,
 71 0,70 0,69 0,68 0,67 0,66 0,65 0,0 0,0 178,0 179,
 0 180,0 181,0 182,0 183,0 184,0 185,0 186,0 188,
 0 189,0 190,0 191,0 192,0 193,0 194,0 195,0 196,
 0 439,158 439,159 439,160 439,161 439,162 439,
 164 439,165 439,166 439,167 439,168 439,169 439,
 298 439,299 439,299 405,299 404,299 402,299 401,
 299 0,89 0))
 Has sense? BTW, I'm using PostGIS version 1.5.0SVN
 > I'll attach the file in a bit.
 I think you attached the file in ticket #297. Could be?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494#comment:22>
