[postgis-devel] [PostGIS] #514: [wktraster] Some functions are missing in the XML reference
PostGIS trac at osgeo.org
Fri Apr 30 08:23:03 PDT 2010
  Reporter:  pracine    |       Owner:  robe
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Old description:
> These functions should added to the XML documentation:
> -st_bandhasnodatavalue
> -st_bandpath
> -postgis_raster_lib_version
> -postgis_raster_lib_build_date
> It would also be good to separate functions accessing (or setting) RASTER
> metadata from functions accessing (or setting) BAND metadata from
> function accessing or setting PIXEL values.
New description:
 -st_bandpath
 metadata from functions accessing (or setting) BAND metadata from function
Ticket URL: <http://trac.osgeo.org/postgis/ticket/514#comment:1>
