[postgis-devel] Should I file a bug on this? ST_Union fails.
Jeff Adams
jadams at azavea.com
Mon Aug 2 06:29:10 PDT 2010
Sorry for cross-posting, but I didn't get any conclusive responses on the
-users mailing list so this may be more a question for the devs.
Union these 16 linestrings, you get a topology exception. Remove any one of
them, you don't. Simplifying and snapping to grid, at any reasonable
precision, did not help my larger real data (though I didn't try with this
little test case).
Is this a bug in ST_Union (or more likely, in Geos' Union)? Isn't it
supposed to be adding the node it complains is missing?
I was attempting to polygonize the linework, and in PostGIS my understanding
is that the way to node the linestrings is to call ST_Union. I eventually
worked around this by importing the data into OpenJump and polygonizing
there (OpenJump is built on JTS, though I don't know if it uses
Geometry.Union or one of the Noder classes to do the linestring noding).
SELECT ST_Union(ARRAY[
ST_GeomFromEWKT('SRID=4326;
LINESTRING(-118.30613361296 33.8122380826708,-118.304098
33.810251,-118.304236 33.810103,-118.304709 33.810071,-118.305765
33.810748,-118.305909 33.809732,-118.306626 33.809556,-118.306593
33.808887,-118.307343 33.808265,-118.307262 33.808031,-118.306361
33.807514,-118.304929 33.807514,-118.304845 33.807291,-118.305287
33.806817,-118.306369 33.806816,-118.306362 33.804825,-118.307257
33.80412,-118.307256 33.803689,-118.306994 33.803306,-118.307001
33.802282,-118.306366 33.801427,-118.304812 33.801424,-118.304852
33.800714,-118.304474 33.799426,-118.304048 33.799149,-118.303735
33.798054,-118.302859 33.798053,-118.302692 33.797818,-118.3043
33.796488,-118.304414 33.796697,-118.305316 33.796699,-118.305309
33.795842,-118.305185 33.795766,-118.307667 33.793712,-118.307871
33.79377,-118.307762 33.794063,-118.308329 33.794165,-118.309331
33.794785,-118.309496 33.794646,-118.309026 33.793433,-118.309301
33.793431,-118.310179 33.792369,-118.311477 33.792408,-118.311221
33.791529,-118.312053 33.789477,-118.314394 33.78809,-118.314441
33.787542,-118.314939 33.787103,-118.314933 33.787655,-118.316174
33.788043,-118.317662 33.786051,-118.317822 33.785331,-118.31926
33.783198,-118.319515 33.783401,-118.31952 33.784353,-118.320133
33.784875,-118.320168 33.785781,-118.320644 33.786331,-118.321187
33.786329,-118.321664 33.785748,-118.322465 33.786108,-118.322465
33.785588,-118.322725 33.785508,-118.322861 33.785552,-118.322863
33.787017,-118.324012 33.786812,-118.324484 33.78618,-118.324536
33.785867,-118.325534 33.786479,-118.327373 33.786445,-118.32739
33.78696,-118.328084 33.7867,-118.328192 33.786312,-118.329673
33.786315,-118.330558 33.786692,-118.331564 33.78613,-118.332317
33.786324,-118.333303 33.785763,-118.333296 33.7829,-118.334243
33.781681,-118.334739 33.781502,-118.336465 33.782973,-118.337471
33.78022,-118.338271 33.779854,-118.33873 33.779245,-118.339713
33.7811,-118.340119 33.779571,-118.340489 33.779635,-118.340011
33.778281,-118.34055 33.777196,-118.34009 33.777247,-118.339995
33.77709,-118.341573 33.776763,-118.342003 33.776325,-118.342988
33.777413,-118.343422 33.776597,-118.342638 33.77558,-118.343555
33.776151,-118.343818 33.776151,-118.344472 33.775277,-118.344577
33.775582,-118.343992 33.776306,-118.344084 33.77655,-118.344886
33.77729,-118.348172 33.779425,-118.349097388008 33.7794492053201)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.307700993013
33.8134536081132,-118.307366 33.813558,-118.306908 33.812743,-118.304434
33.810553,-118.304622 33.810418,-118.30525 33.810988,-118.305923
33.810719,-118.306 33.810101,-118.306704 33.809973,-118.306688
33.809247,-118.307466 33.808468,-118.307319 33.808037,-118.306547
33.807529,-118.30539 33.807538,-118.305338 33.807293,-118.305635
33.806943,-118.30707 33.806906,-118.307423 33.806221,-118.307375
33.805322,-118.307014 33.80495,-118.307489 33.8043,-118.30749
33.803281,-118.307227 33.803082,-118.30738 33.802612,-118.307223
33.802298,-118.307267 33.801238,-118.306917 33.801077,-118.305484
33.801074,-118.305272 33.800949,-118.305345 33.800715,-118.304968
33.799428,-118.305239 33.7988,-118.304129 33.7988,-118.303185
33.797819,-118.304138 33.797653,-118.304135 33.797435,-118.303851
33.797269,-118.306955 33.794712,-118.307505 33.794711,-118.30766
33.794122,-118.30946 33.793419,-118.310673 33.792496,-118.311722
33.792499,-118.31194 33.792328,-118.311811 33.791541,-118.312067
33.79133,-118.312203 33.791282,-118.312207 33.792323,-118.312605
33.793072,-118.313723 33.79307,-118.314322 33.792613,-118.314338
33.791002,-118.313872 33.790674,-118.314438 33.790629,-118.314586
33.790086,-118.31479 33.790069,-118.314784 33.790818,-118.315957
33.790293,-118.316272 33.79029,-118.316276 33.789496,-118.317512
33.788665,-118.317508 33.78897,-118.317922 33.789289,-118.319415
33.789292,-118.319822 33.788966,-118.319822 33.787578,-118.320026
33.787281,-118.320228 33.787282,-118.320228 33.788607,-118.321767
33.787298,-118.321769 33.78668,-118.322724 33.785959,-118.32286
33.786049,-118.322864 33.787241,-118.324012 33.786846,-118.324477
33.786221,-118.324536 33.785867,-118.325534 33.786479,-118.327373
33.786445,-118.32739 33.78696,-118.328084 33.7867,-118.328192
33.786312,-118.329976 33.786391,-118.330383 33.786205,-118.330798
33.786434,-118.331589 33.786157,-118.333241 33.786522,-118.33319
33.785878,-118.333446 33.785733,-118.333249 33.78524,-118.333293
33.783478,-118.333551 33.783132,-118.33375 33.783734,-118.337252
33.784222,-118.337272 33.78409,-118.337582 33.78435,-118.337953
33.784311,-118.338888 33.785102,-118.339435 33.784442,-118.339977
33.784578,-118.340642 33.783119,-118.341129 33.782651,-118.341162
33.782983,-118.340942 33.783344,-118.34147 33.784,-118.342781
33.785206,-118.343369 33.785377,-118.343965 33.78596,-118.344404
33.785906,-118.345565 33.785188,-118.346632 33.784948,-118.346263
33.785593,-118.345294 33.786038,-118.343339 33.787391,-118.342914
33.788404,-118.344329 33.789551,-118.344834 33.789647,-118.345547
33.790826,-118.346802 33.791674,-118.346973 33.792355,-118.347339
33.79248,-118.348118 33.793207,-118.348143 33.793939,-118.348962
33.793846,-118.349103 33.793586,-118.349468 33.793472,-118.350038
33.792956,-118.350515 33.792864,-118.351036 33.792069,-118.353376
33.790784,-118.355734 33.789024,-118.355245 33.788011,-118.356367
33.786715,-118.354972 33.78611,-118.354149 33.786328,-118.354231
33.784792,-118.354544 33.784053,-118.355962 33.784602,-118.357489
33.785796,-118.358813435042 33.7855261326062)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.304848630339
33.8111422006911,-118.304605 33.810709,-118.303261 33.809465,-118.303066
33.808994,-118.303047 33.808764,-118.304678 33.808727,-118.304204
33.807417,-118.303217 33.807414,-118.303039 33.807564,-118.30284
33.807286,-118.303155 33.80711,-118.305469 33.807118,-118.305132
33.805605,-118.304916 33.805121,-118.304567 33.80512,-118.304624
33.804945,-118.303265 33.801157,-118.302756 33.801007,-118.300683
33.797815,-118.301197 33.797388,-118.301319 33.797708,-118.302268
33.79771,-118.302535 33.797461,-118.302534 33.7971,-118.301946
33.796762,-118.302558 33.796716,-118.302656 33.796386,-118.302522
33.796285,-118.303826 33.795209,-118.304173 33.795212,-118.304241
33.794877,-118.305718 33.793661,-118.307238 33.793667,-118.307507
33.793434,-118.30751 33.792915,-118.307226 33.792558,-118.307047
33.792557,-118.307673 33.792037,-118.307796 33.792023,-118.307974
33.792387,-118.30957 33.792391,-118.309312 33.791501,-118.3106
33.790482,-118.310854 33.790483,-118.311109 33.790064,-118.312064
33.789273,-118.314397 33.78883,-118.314404 33.78825,-118.314596
33.78801,-118.314802 33.788004,-118.314793 33.788736,-118.316043
33.788337,-118.316826 33.788339,-118.317112 33.787982,-118.317143
33.786759,-118.317543 33.786583,-118.317784 33.787485,-118.318591
33.787418,-118.319824 33.787894,-118.319819 33.785511,-118.320017
33.785203,-118.320221 33.78533,-118.320225 33.786017,-118.320425
33.786482,-118.321244 33.78648,-118.321721 33.785898,-118.322521
33.78602,-118.322522 33.785558,-118.322861 33.785552,-118.322863
33.785867,-118.325473 33.786414,-118.327192 33.786568,-118.327159
33.786393,-118.32913 33.786126,-118.330072 33.786179,-118.330661
33.78648,-118.331149 33.786488,-118.33146 33.786208,-118.33199
33.786395,-118.333088 33.786362,-118.333197 33.784267,-118.333617
33.783891,-118.333541 33.782489,-118.334243 33.781681,-118.334727
33.781597,-118.337372 33.783843,-118.337801 33.782229,-118.337775
33.78179,-118.337228 33.781161,-118.338482 33.780641,-118.338787
33.78142,-118.339889 33.781405,-118.340305 33.78154,-118.340372
33.779912,-118.340702 33.779767,-118.342003 33.779991,-118.342707
33.778679,-118.343946 33.780445,-118.343594 33.781199,-118.34191
33.782263,-118.341886 33.783636,-118.343458 33.784865,-118.344662
33.785274,-118.345142 33.784764,-118.346172 33.784403,-118.347436
33.784214,-118.347888 33.784652,-118.348115 33.7844,-118.348775
33.784432,-118.350288 33.784162,-118.351655 33.782986,-118.351467
33.782198,-118.350625 33.781652,-118.350715 33.781321,-118.350949
33.781314,-118.352025 33.78202,-118.352465 33.782066,-118.352774
33.780824,-118.352971 33.780656,-118.355227 33.782384,-118.355679
33.78227,-118.355689 33.781705,-118.356677 33.781749,-118.357000162508
33.7819097651871)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.357169759789
33.7834490284716,-118.357033 33.783851,-118.357898
33.784215,-118.359328629247 33.784207709798)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.303089803431
33.8096422063087,-118.30301 33.808914,-118.302281
33.808821,-118.302230554228 33.8087352371279)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.301521804907
33.8075302921941,-118.301284 33.807126,-118.299501 33.805505,-118.29965
33.805337,-118.300478 33.806088,-118.300959 33.805355,-118.301754
33.80542,-118.302461 33.8049,-118.300752 33.803522,-118.300736
33.802591,-118.29908 33.800009,-118.299078 33.79936,-118.298126
33.798199,-118.297897 33.798196,-118.297542 33.798694,-118.296491
33.797739,-118.297443 33.797578,-118.297399 33.796956,-118.297636
33.796822,-118.29767 33.797187,-118.297998 33.797514,-118.299227
33.797578,-118.29968 33.797272,-118.299688 33.796031,-118.299392
33.795709,-118.299874 33.795499,-118.299915 33.794929,-118.30138
33.793734,-118.302011 33.793739,-118.302555 33.793521,-118.301943
33.79327,-118.302688 33.79317,-118.302722 33.792626,-118.302976
33.792415,-118.303621 33.792417,-118.303482 33.791996,-118.304351
33.791287,-118.305664 33.791398,-118.305345 33.790471,-118.306815
33.790407,-118.307346 33.790006,-118.306795 33.789544,-118.306567
33.789543,-118.306835 33.789398,-118.307507 33.789402,-118.307649
33.789276,-118.307718 33.788531,-118.307919 33.788787,-118.309149
33.788796,-118.309397 33.788545,-118.30911 33.788213,-118.309956
33.787547,-118.31168 33.787433,-118.311612 33.786862,-118.312713
33.785993,-118.312834 33.785971,-118.31279 33.786371,-118.313089
33.786427,-118.313412 33.786157,-118.314404 33.786276,-118.314426
33.785601,-118.313755 33.785209,-118.314624 33.785098,-118.314696
33.784527,-118.315529 33.784589,-118.315858 33.785109,-118.316121
33.786327,-118.316484 33.786947,-118.317697 33.785776,-118.317923
33.784866,-118.318853 33.784151,-118.318883 33.783487,-118.319275
33.783116,-118.319695 33.78206,-118.319977 33.782698,-118.319707
33.78376,-118.319754 33.784296,-118.320396 33.784866,-118.32043
33.785632,-118.321971 33.785845,-118.322728 33.785326,-118.324198
33.786022,-118.324267 33.785631,-118.325005 33.786193,-118.325794
33.786532,-118.326632 33.786509,-118.326488 33.786846,-118.32664
33.786845,-118.326819 33.787409,-118.326993 33.787409,-118.327278
33.786916,-118.327253 33.786443,-118.328893 33.786306,-118.32939
33.786114,-118.330125 33.786169,-118.330733 33.78648,-118.331513
33.786198,-118.333173 33.78661,-118.333114 33.785919,-118.333302
33.785783,-118.333173 33.785281,-118.333247 33.784311,-118.333624
33.783764,-118.333511 33.782611,-118.334297 33.781646,-118.336277
33.783248,-118.336621 33.78325,-118.338452 33.784795,-118.33917
33.784288,-118.339476 33.783346,-118.339385 33.782988,-118.339631
33.782794,-118.338909 33.781621,-118.340143 33.781607,-118.340929
33.780816,-118.341792 33.780975,-118.342079 33.780189,-118.34225
33.780101,-118.342615 33.780504,-118.342196 33.781688,-118.341381
33.783009,-118.341979 33.783894,-118.343081 33.784838,-118.344449
33.785454,-118.345181 33.784944,-118.346233 33.784494,-118.346648
33.784836,-118.349171 33.784624,-118.349984 33.784341,-118.353068
33.785771,-118.353056 33.783686,-118.352762 33.783051,-118.352003
33.782798,-118.352097 33.782229,-118.352621 33.782097,-118.352685
33.782538,-118.353197 33.782903,-118.353692 33.782857,-118.353489
33.782097,-118.353978 33.782284,-118.354301 33.782759,-118.354704
33.782671,-118.354936 33.782421,-118.355333 33.782578,-118.355198
33.782707,-118.355458 33.783551,-118.35688 33.783258,-118.35714707651
33.7835707923095)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.357401619265
33.7838689054455,-118.357879 33.784428,-118.357962
33.785686,-118.358889500305 33.7854213315776)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.308746858587
33.8175427468454,-118.308708 33.817061,-118.30847770782 33.8169411415257)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.307561901608
33.8160004041704,-118.307515 33.814991,-118.307658
33.814793,-118.307628474836 33.8146729847436)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.307382137965
33.8136716631955,-118.307365 33.813602,-118.307043979511 33.813016336587)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.307042066317
33.8130128461942,-118.306881 33.812719,-118.303923 33.810094,-118.304036
33.80994,-118.304256 33.810138,-118.304885 33.810011,-118.305908
33.810079,-118.305874 33.80954,-118.306606 33.809107,-118.306362
33.808818,-118.307278 33.808159,-118.30716 33.807777,-118.306317
33.807502,-118.304689 33.807501,-118.304588 33.807291,-118.305031
33.806816,-118.306114 33.806818,-118.306106 33.804825,-118.307088
33.804119,-118.306973 33.80209,-118.30611 33.801426,-118.304556
33.801423,-118.303994 33.799329,-118.304026 33.798643,-118.303713
33.798054,-118.302711 33.798053,-118.302435 33.797818,-118.305056
33.79566,-118.306831 33.795665,-118.306617 33.795237,-118.30609
33.794802,-118.307666 33.793498,-118.309843 33.792447,-118.310571
33.792504,-118.310883 33.791627,-118.312094 33.790712,-118.314204
33.790586,-118.314398 33.790274,-118.314358 33.789593,-118.314589
33.789463,-118.314711 33.789504,-118.314661 33.790251,-118.315831
33.790306,-118.315512 33.789507,-118.316943 33.78944,-118.31714
33.789014,-118.316546 33.788727,-118.317516 33.78804,-118.31751
33.788755,-118.318006 33.789196,-118.319333 33.789198,-118.319822
33.788747,-118.319822 33.786954,-118.320026 33.786657,-118.320254
33.786592,-118.320228 33.78807,-118.321768 33.786763,-118.321722
33.786007,-118.322725 33.785508,-118.322861 33.785552,-118.322863
33.786315,-118.330522 33.786672,-118.331562 33.786128,-118.332314
33.786323,-118.33323 33.785922,-118.333379 33.784045,-118.333293
33.782898,-118.334243 33.781681,-118.334734 33.78154,-118.336434
33.782989,-118.337364 33.780521,-118.338572 33.779886,-118.340304
33.779689,-118.341613 33.779914,-118.342106 33.779586,-118.342518
33.77815,-118.342987 33.777958,-118.344659 33.7805,-118.343381
33.780906,-118.343632 33.781143,-118.342398 33.783934,-118.343512
33.784819,-118.344915 33.784888,-118.34587 33.784421,-118.347695
33.784125,-118.348113 33.78462,-118.350786 33.78368,-118.351221
33.783293,-118.349414 33.781941,-118.349272 33.780323,-118.351328
33.780357,-118.352627 33.78109,-118.353084 33.77979,-118.353488
33.779397,-118.353845 33.77931,-118.354605 33.779992,-118.354302
33.780391,-118.354036 33.781226,-118.355018 33.780952,-118.355374
33.781143,-118.3558 33.780502,-118.356525457447 33.7806494603301)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.357238541314
33.7806010373294,-118.357325612665 33.7805398901349)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.357342573846
33.7805383054012,-118.357615033695 33.7806751225237)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.357693277501
33.7809493965079,-118.357455525965 33.7813634913787)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.357444440338
33.7838848876304,-118.357453 33.783942,-118.357982
33.784141,-118.35917094071 33.7841021918463)'),
ST_GeomFromEWKT('SRID=4326;LINESTRING(-118.29510929418
33.7752042976004,-118.295895 33.775667,-118.295975 33.775514,-118.296254
33.775883,-118.296184 33.778951,-118.296341 33.77951,-118.297119
33.780547,-118.298343 33.780232,-118.299024 33.779858,-118.299207
33.778491,-118.299472 33.778718,-118.301295 33.779122,-118.301733
33.778885,-118.30297 33.778888,-118.303043 33.779769,-118.303358
33.779732,-118.303983 33.778992,-118.303682 33.77972,-118.304919
33.779888,-118.304667 33.780495,-118.303892 33.780511,-118.30404
33.781208,-118.303359 33.781416,-118.304219 33.782044,-118.304214
33.782771,-118.305056 33.782756,-118.3054 33.783381,-118.305683
33.783381,-118.30588 33.783663,-118.305981 33.7843,-118.307116
33.785157,-118.307545 33.785104,-118.309046 33.78565,-118.309874
33.786831,-118.3097 33.787235,-118.309963 33.787412,-118.310398
33.787411,-118.311112 33.78786,-118.311488 33.787548,-118.31177
33.787632,-118.311792 33.787809,-118.311122 33.788364,-118.312091
33.788904,-118.312363 33.789343,-118.31268 33.789485,-118.310864
33.791643,-118.309697 33.791608,-118.309507 33.792027,-118.309862
33.792454,-118.308861 33.79445,-118.3088 33.794935,-118.30625
33.796639,-118.30641 33.796778,-118.305036 33.796853,-118.304479
33.7973,-118.305042 33.797743,-118.305281 33.797743,-118.304355
33.798502,-118.303949 33.79877,-118.303609 33.798097,-118.300308
33.798092,-118.301358 33.800068,-118.301353 33.800585,-118.301167
33.801237,-118.30032 33.802052,-118.29926 33.80198,-118.299237
33.802909,-118.298648 33.804168,-118.297427 33.804616,-118.29581032417
33.804010103814)')
]) as broken;
NOTICE: TopologyException: found non-noded intersection between LINESTRING
(-118.323 33.7869, -118.323 33.7869) and LINESTRING (-118.323 33.7869,
-118.323 33.7869) at -118.323 33.7869
ERROR: GEOS union() threw an error!
********** Error **********
SQL state: XX000
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100802/6da0e3bc/attachment.html>
