[postgis-devel] regression-tests failing on ubuntu 64 on trunk
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Aug 3 01:32:06 PDT 2010
Nicklas Avén wrote:
> I get failed regression-tests on trunk
> I get 5 failed tests on ubuntu 64, but all looks good in windows.
> postgis-1.5.1 passes all tests on same ubuntu-box
> I attach the log
> /Nicklas
Hmmm looks like the issue is that the parser code in
liblwgeom/lwgparse.c thinks that the detected error position has changed.
Are you sure that you did a complete rebuild on both platforms,
including a "make clean" to do a rebuild of liblwgeom? I can understand
that the parse position could change, but if it did then it should
affect all platforms and not just one.
Can you narrow it down using an SVN bisect?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
