[postgis-devel] [PostGIS] #555: Ability to define a geometry column as Polyhedral surface
PostGIS trac at osgeo.org
Fri Aug 6 01:09:06 PDT 2010
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by colivier):
 For ST_Area it's a 'normal' behaviour as it care on sub geometry only.
 And PolyhedralSurface is a collection of connected polygons.
 So ST_Area should return the sum area of each sub polygon inside.
 So it should be OK for this one.
 I guess i will also have to 'flag' each supported function
 in the documentation with a 'PS_support'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/555#comment:4>
