[postgis-devel] [PostGIS] #555: Ability to define a geometry column as Polyhedral surface
PostGIS trac at osgeo.org
Fri Aug 6 05:06:10 PDT 2010
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Olivier,
 Now I remember why I had my suspicions about ST_Area.  I don't think our
 ST_Area supports 2.5D polygons and aren't all the faces of the polyhedral
 surface 2.5D polygons?  In which case -- it probably needs some work.
 But saying ST_Dump works with polyhedral surfaces I guess is safe to say.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/555#comment:6>
