[postgis-devel] Polyhedral, 3d and distance
Olivier Courtin
olivier.courtin at oslandia.com
Mon Aug 9 15:14:02 PDT 2010
On Aug 9, 2010, at 8:13 PM, Nicklas Avén wrote:
Hi Nicklas,
> This polyhedral thing is really interesting. I have been thinking
> about the distance-functions against 3D.
> The word polyhedral is new to me and I don't know more about it than
> what Olivier has written in his post.
Well it's just a collection of connected polygons.
They could be either 2D, or 3D.
And if they are 3D, they could also lead to enclose a solid.
(a cube for instance).
> I have a few questions:
> Olivier, in your post in January
> http://postgis.refractions.net/pipermail/postgis-devel/2010-January/008384.html
> you say that :
> resulting PolyhedralSurface must be convex (and without hole)
> is that a logical limitation or a limitation in the standard.
> I mean if the resulting geometry has to be convex it will be hard to
> describe things like the land shape, a mountain a valley etc.
I was wrong on this point, the convex aspect is not (at all) required
by the spec.
> as described in the post above:
> every polygon mean a face (with all points on the same plan...
> As I understand it (I like to add that so it hurts a little less
> when I'm wrong), a plane can be defined
> by 3 points. But what when we have 4 or more points. There are
> several situations where that is no problem, but
> if all 4 corners have unique coordinates both x, y and z then I
> suspect we can get floating point problems.
> I guess we will have to find a way to deal with inaccurancy.
You're right, there's a floating point imprecision issue here.
And except in naive integer examples we never could say yes or no
on coplanar 4 points tests, so we have to deal on implementation
with such imprecision
And that's one of the reason why a lot of 3D apps don't deal with
PolyhedralSurface, but use TIN instead...
I realize quite recently that it would be a really good idea to
implement
also TIN and Triangle. To be consistent with spec first (SQL/MM),
and to have more additional external lib availables to help with
meshes handling.
> From my understanding it can be compared to saying all points have
> to be exactly on the line. It is ok if it is two points, then it is
> no problem and it is ok
> if the points have two constant coordinates like 'LINESTRING( 1 1 1,
> 1 1 3, 1 1 10, 1 1 12)' but if the line represents a slope there
> might be problems.
In a way yes !
except you deal with one more axis ;)
> This has to be something fundamental when calculating distances
> against polyhedrals. I don't know the algoritms,
> but from some reading I think the way to do it, for example the
> distance between a point and a polyhedral is to
> "project the point to the plane"
> check if the point is in the polygon on the plane
> if so, the distance is between the projected point and the original
> point.
> If not we have to do a distance calculation against the edges of the
> polygon. Like today, but in 3D.
I didn't yet really/fully analyze the Distance issue.
But yes that's the general idea for 3D Surfaces.
One thing i don't know now is if there's a better algo
to avoid to check each faces, one by one.
We could also had a Point In Polyhedron prior
check on closed surfaces, for distance = 0 cases.
> The point is that the central part of this is the plane. How to
> handle that if the points
> are not exactly on the same plane.
It have to be coplanar 'enough'.
As they will (quite) never be strictly coplanar.
> Does this have an obvious solution that I'm missing or is it
> problems we will have to deal with?
Yes we have to deal with.
> The same problem will occur with a "normal" polygon that is tilted.
Not sure to follow you on this point
What do you mean tilted ?
> I see this as a little similar problem as the inability to get an
> intersection between a point and a linestring.
> How to handle the inaccuracy?
Hopefully in real world we are more concerned
by Point in Polygon use case :)
> I might be totally lost in this.
That's a really important part of the analysis/topological
implementation functions.
A lot of 3D libs don't (have to) really care about numerical
robustness as they're primarily
design mostly for rendering.
> Another difference between calculating distance in 2D and 3D I have
> realized is that two linestring can have their closest parts on the
> edges of both. Not like 2D where at least one of the geometries must
> be closest with a vertex.
> That is just an observation.
Olivier
