[postgis-devel] [PostGIS] #562: ST_DWithin gives wrong answer
PostGIS trac at osgeo.org
Tue Aug 10 12:34:45 PDT 2010
 Reporter:  pramsey  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 1.5.2
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by pramsey):
 The problem is that the gbox for the polygon is being incorrectly
 calculated. It is not correctly recognizing that it contains the x-axis
 pole, which greatly underdetermines it. (Also the y-axis pole, to a lesser
 negative effect.)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/562#comment:1>
