[postgis-devel] Call for 1.5.2 release
Paul Ramsey pramsey at cleverelephant.ca
Tue Aug 10 16:38:36 PDT 2010
Yeah, the GUI is problematic, as the changes are very substantial, and
will need lots of testing. I just now tried to build and run on OS/X
and got
shp2pgsql-gui(77973) malloc: *** error for object 0x100e0e960: pointer
being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
Not sure if folks have done a build and test on Win32 yet. For 1.5.2
it would be nicer to keep the current GUI, no?
P.
(Of course, I have a reason to not want to change things, having just
finished a couple workshops full of screenshots of the *old* GUI.)
On Mon, Aug 2, 2010 at 3:45 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
>> I am fine with a release. Let me know when you feel the branch has risen
>> to the level of cutting a tar ball, or do you think we are there right now?
>> P.
> The changelog looks reasonably sensible, although I didn't realise until
> just now that Mark's shp2pgsql GUI changes had been merged into 1.5 branch.
> IMO that's quite a large change for a bugfix release on an existing branch.
> The other issue, of course, is that yesterday there was an API change in the
> 9.0 analyze function:
> http://archives.postgresql.org/pgsql-committers/2010-08/msg00013.php. We
> should code up a fix for this before cutting the release.
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
