[postgis-devel] make astyle
Nicklas Avén nicklas.aven at jordogskog.no
Wed Aug 11 04:09:21 PDT 2010
I have 1.23 in windows
what is the latest?
/Nicklas
On Wed, 2010-08-11 at 13:03 +0200, Olivier Courtin wrote:
> On Aug 11, 2010, at 12:23 PM, Nicklas Avén wrote:
> > Maybe it is only that make astyle has not been used on many files.
> > I remember that there were a discussion on the topic some months ago
> > that there might be differences.
> > I attach the patch showing the result of my astyle compared to latest
> > trunk. At least in the beginning of the file it looks like quite
> > obvious
> > changes that has been done.
> I launch on a new local copy (r5809) an astyle with astyle 1.23
> i get a lot of diff, but not on exactly on the same files as yours.
> On mine:
> mac:postgis ol$ svn diff | grep Index
> Index: liblwgeom/lwcollection.c
> Index: liblwgeom/lwout_wkt.c
> Index: liblwgeom/lwpsurface.c
> Index: liblwgeom/lwsegmentize.c
> Index: liblwgeom/lwspheroid.c
> Index: liblwgeom/lwgparse.c
> Index: liblwgeom/lex.yy.c
> Index: liblwgeom/lwgeom.c
> Index: liblwgeom/lwline.c
> Index: liblwgeom/g_box.c
> Index: liblwgeom/stringbuffer.c
> Index: liblwgeom/cunit/cu_out_kml.c
> Index: liblwgeom/cunit/cu_polyhedralsurface.c
> Index: liblwgeom/cunit/cu_libgeom.c
> Index: liblwgeom/cunit/cu_wkb.c
> Index: liblwgeom/cunit/cu_geodetic.c
> Index: liblwgeom/cunit/cu_out_svg.c
> Index: liblwgeom/cunit/cu_algorithm.c
> Index: liblwgeom/cunit/cu_out_geojson.c
> Index: liblwgeom/cunit/cu_print.c
> Index: liblwgeom/cunit/cu_homogenize.c
> Index: liblwgeom/cunit/cu_wkt.c
> Index: liblwgeom/cunit/cu_tester.c
> Index: liblwgeom/cunit/cu_out_gml.c
> Index: liblwgeom/g_serialized.c
> Index: liblwgeom/lwhomogenize.c
> Index: liblwgeom/lwout_gml.c
> Index: liblwgeom/lwout_kml.c
> Index: liblwgeom/lwout_wkb.c
> Index: liblwgeom/ptarray.c
> Index: liblwgeom/lwgeodetic.c
> Index: postgis/geography_inout.c
> Index: postgis/lwgeom_gist.c
> Index: postgis/lwgeom_geos_split.c
> Index: postgis/lwgeom_export.c
> Index: postgis/lwgeom_inout.c
> Index: postgis/lwgeom_ogc.c
> Index: postgis/lwgeom_geos.c
> Index: postgis/lwgeom_geos_clean.c
> Index: postgis/lwgeom_in_gml.c
> Index: postgis/lwgeom_in_kml.c
> Index: loader/structure.c
> Index: loader/cunit/cu_list.c
> Index: loader/cunit/Makefile
> Index: loader/shp2pgsql-gui.c
> Index: loader/shp2pgsql-core.c
> Index: extras/wkb_reader/readwkb.c
>  From your diff:
> For information what is the astyle version you use Nicklas ?
> There's a lot of files (in the two list) impacted
> by some previous commits of mine.
> I could apply a make astyle commit quite soon,
> as soon as i finish the #561 (impact a lot of files)
> P.S: if someone have a  .vimrc compliant with astyle
>           settings i'm interrested :)
> Olivier
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
