[postgis-devel] [PostGIS] #565: shp2pgsql-gui crashes when selecting second file
trac at osgeo.org
Wed Aug 11 06:04:15 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Tried the new commit on Windows XP.
It works fine if I only have one file. If I try to select a second file,
it crashes after selection of second file and some mouse movement.
Also can we default the geometry name to geom. I think we said we would
change our standard default to geom (form the_geom) for 2.0.
Can we also default to lower casing the table name.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/565>
