[postgis-devel] ST_Perimeter and ST_Perimeter3D what should	Polyhedral Surface return?
    Olivier Courtin
    olivier.courtin at oslandia.com
    Fri Aug 13 10:53:58 PDT 2010
On Aug 13, 2010, at 7:43 PM, Nicklas Avén wrote:
Hi all,
> This about perimeter in 3D.
> When I thought about it it lead me to the question when a in
> polyhedral
> surface becomes a polyhedron. Like a closed linestring, can be a
> linestring without turning to a polygon.
> The two questions connect in that, when the surface turns to a volum I
> guess there is no perimeter like there is no length of line when the
> linestring becomes a polygon.
You're right Nicklas, when the PolyhedralSurface (and now TIN)
are Closed, the Perimeter3D have to return 0
And as Regina said, the Perimeter/Perimeter3D should only
care about 'external' edge length.
In fact all the edges connected to only one face.
I create a ticket on this
> Olivier, I thought about it also because of the discussion the other
> day
> about testing if a point is inside a closed polyhedral when doing
> distance-measures. If there is no way to show that it is a polyhedron
> there should be the distance to the surfaces even if the point is
> inside?
> I mean the distance from a point to a closed linestring is the
> distance
> to the linestring even if the point is inside the closed line.
After our discussion, i really think that having only LWGEOM struct
for connected surfaces (PolyhedralSurface, TIN) is not enough.
We will spend a lot of time/energy in each spatial function to compute
again the topology beneath.
There's a need to have a point/edge/face model.
Need to explore this way...
Olivier
