[postgis-devel] [PostGIS] #577: possible memory leak with buffer()
trac at osgeo.org
Sat Aug 21 10:36:59 PDT 2010
Reporter: davideps | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone:
Component: postgis | Version: 1.3.X
Resolution: invalid | Keywords: memory buffer intersect dwithin
Comment(by nicklas):
I just want to give a few comments even if the ticket is dead.
David
Your query doesn't call st_dwithin only 320000 times. Because you test
every possible combination of polygons you actually calls the function
320000*320000 times. So it might be understandable. But it sounds quite
long anyway.
PostGIS 1.5 should handle this better too. Especially if the polygons is a
little bit complex with many vertxes upgrading might give quite a big
difference.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/577#comment:5>
