[postgis-devel] [wktraster] Core tests failure for r5841
Jorge Arévalo jorge.arevalo at deimos-space.com
Mon Aug 23 04:38:55 PDT 2010
On Mon, Aug 23, 2010 at 1:04 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
> Hi,
> I've noticed current revision of WKT Raster is broken.
> Running the core tests for r5841 ends up with assertion and
> load of warnings:
> ./testapi
> 1111 pixtype = 2
> Raster starts with 0 bands
> First point on convexhull ring is 0.5,0.5
> Second point on convexhull ring is 256.5,1280.5
> Third point on convexhull ring is 1280.5,1536.5
> Fourth point on convexhull ring is 1024.5,256.5
> Fifth point on convexhull ring is 0.5,0.5
> Testing polygonize function
> Testing 1BB band
> WARNING: rt_band_set_nodata: NODATA value for 1BB band got truncated from 2
> to 0
> WARNING: rt_band_set_nodata: NODATA value for 1BB band got truncated from 3
> to 1
> WARNING: Pixel value for 1BB band got truncated from 2 to 0
> WARNING: Pixel value for 1BB band got truncated from 3 to 1
> Testing 2BB band
> WARNING: rt_band_set_nodata: NODATA value for 2BUI band got truncated from 4
> to 0
> WARNING: rt_band_set_nodata: NODATA value for 2BUI band got truncated from 5
> to 1
> WARNING: Pixel value for 2BUI band got truncated from 4 to 0
> WARNING: Pixel value for 2BUI band got truncated from 5 to 1
> Testing 4BUI band
> WARNING: rt_band_set_nodata: NODATA value for 4BUI band got truncated from
> 16 to 0
> 17 to 1
> WARNING: Pixel value for 4BUI band got truncated from 35 to 3
> Testing 8BUI band
> WARNING: rt_band_set_nodata: NODATA value for 8BUI band got truncated from
> 256 to 0
> WARNING: Pixel value for 8BUI band got truncated from 256 to 0
> Testing 8BSI band
> WARNING: rt_band_set_nodata: NODATA value for 8BSI band got truncated from
> -129 to 127
> 129 to -127
> WARNING: Pixel value for 8BSI band got truncated from -129 to 127
> WARNING: Pixel value for 8BSI band got truncated from 129 to -127
> Testing 16BSI band
> WARNING: rt_band_set_nodata: NODATA value for 16BSI band got truncated from
> -32769 to 32767
> 32769 to -32767
> WARNING: Pixel value for 16BSI band got truncated from -32769 to 32767
> WARNING: Pixel value for 16BSI band got truncated from 32769 to -32767
> ERROR: Coordinates ouf of range
> Testing 16BUI band
> WARNING: rt_band_set_nodata: NODATA value for 16BUI band got truncated from
> 65536 to 0
> WARNING: Pixel value for 16BUI band got truncated from 65536 to 0
> Testing 32BUI band
> WARNING: rt_band_set_nodata: NODATA value for 32BUI band got truncated from
> 4.29497e+09 to 0
> WARNING: Pixel value for 32BUI band got truncated from 4.29497e+09 to 0
> Testing 32BSI band
> WARNING: rt_band_set_nodata: NODATA value for 32BSI band got truncated from
> 2.14748e+09 to -2.14748e+09
> WARNING: Pixel value for 32BSI band got truncated from 2.14748e+09 to
> -2.14748e+09
> Testing 32BF band
> Testing 64BF band
> Testing band hasnodata flag
> testapi: rt_api.c:545: rt_band_get_data: Assertion `((void *)0) != band'
> failed.
> make[2]: *** [check] Aborted
> make[2]: Leaving directory
> `/home/mloskot/dev/wktraster/_svn/trunk/test/core'
> make[1]: *** [check] Error 2
> make[1]: Leaving directory `/home/mloskot/dev/wktraster/_svn/trunk/test'
> make: *** [check] Error 2
> The assertion is serious and happens in crucial function.
> I checked and the last healthy revision seems to be r5811.
> Pierre, Jorge, could you re-validate your recent commits?
> You do run "make check" before every commit, don't you?
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
The problem seems to be in the 1BB band of the testing raster. Working
on it... And yes, I always do make check before commit, but I'll check
my commits again :-)
Best regards,
Jorge Arévalo
DEIMOS Space
Internet & Mobilty Division
Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
28760 Tres Cantos (Madrid)
Tel: +34 91 806 34 50 - ext: 155
http://gis4free.wordpress.com
