[postgis-devel] [wktraster] Core tests failure for r5841
Mateusz Loskot
mateusz at loskot.net
Tue Aug 24 03:21:37 PDT 2010
On 24/08/10 11:08, Jorge Arévalo wrote:
> make post-install-check works for me too... Maybe is a problem with
> PostGIS/GEOS/PROJ versions... here my versions
> PostgreSQL 8.4.4 on i486-pc-linux-gnu, compiled by GCC gcc-4.4.real
> (Ubuntu 4.4.1-4ubuntu8) 4.4.1, 32-bit
> Postgis 1.4.2 - 2010-08-05 17:36:12
> GEOS: 3.3.0-CAPI-1.6.1
> PROJ: Rel. 4.7.1, 23 September 2009
> WKTRaster 0.1.6d - 2010-08-18 13:49:03
> I'll do the test with a newer version of postgis (2.0.0SVN, like you,
> for example).
OK, thanks.
> A minor issue: the rtpostgis_reg database created for postinstall
> check is not deleted by default. Mateusz, did you change it for any
> reason? (r5822 was the previous version)
Which changeset you mean exactly. The following is r5823
and some changes in test/regress/run_test.in happened.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
