[postgis-devel] [wktraster] Core tests failure for r5841
Mateusz Loskot mateusz at loskot.net
Tue Aug 24 03:47:41 PDT 2010
On 24/08/10 11:32, Jorge Arévalo wrote:
> 2010/8/24 Mateusz Loskot<mateusz at loskot.net>:
>> On 24/08/10 11:08, Jorge Arévalo wrote:
>>> A minor issue: the rtpostgis_reg database created for postinstall
>>> check is not deleted by default. Mateusz, did you change it for any
>>> reason? (r5822 was the previous version)
>> Which changeset you mean exactly. The following is r5823
>> and some changes in test/regress/run_test.in happened.
> Yes, sorry, my mistake. I mean the last change on
> test/regress/run_test.in. A little change:
> http://trac.osgeo.org/postgis/changeset/5823/spike/wktraster/test/regress/run_test.in
> May I change the DROP option again, or is a bad idea?
IMO, we should follow PostGIS' approach:
AFAIU, it is yes, I'd re-enable the drop option.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
